Thrust Rod Busings 2008 BMW 335I - Bimmerfest - BMW Forums
Old 05-15-2014, 06:48 PM
BMWXX55 BMWXX55 is offline
Mein Auto: 2014 BMW X5 35D, BMW 435i
Hi does anyone know where to get a good deal on bushings? Do the M3 ones fit? Does anyone know how to install them therselves? Thanks
Old 05-16-2014, 11:49 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
getbmwparts.com for OEM. Are you just replacing the bushings or the entire Arm?
Old 05-16-2014, 11:54 AM
I am not sure if i should change just the bushings or thw whole arm. Do you have any suggestions
Old 05-16-2014, 12:07 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
If you don't have a press, it's easier to just replace the entire arm.
Make sure to preload the suspension before torquing things down
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
