Engine shaking at idle - Bimmerfest - BMW Forums
Old 05-16-2014, 01:16 PM
maverick17036 maverick17036 is offline
Mein Auto: 2010 328i (coupe) xdrive
Hello all! In March I bought this 2010 328i Xdrive Coupe and now I'm having some engine issues. It seems to randomly and slightly shake when I first start it and when its at idle. I also feel it when I'm in reverse backing slowly into a parking spot.
Let's start with some history...A few weeks after I bought the car, I get a random check engine light (code P0306- cylinder 6 misfire detected) and I couldn't drive above about 30 mph. It was sputtering really bad. I replaced all spark plugs and ignition coils myself which fixed the issue (btw after I complained, the dealer gave me a check for $700 to cover the cost of all the parts). Now I notice this idling issue that wasn't happening before. Moreover, I might be losing oil. I changed the oil a month ago. After replacing it and driving it for a day my level was slightly below the max line. Now its down to the half way point between max and minimum and I smell oil burning at times. Not sure if this oil issue is related to the idling issue.
Anyway, I've done my research and the rough idling/shaking issue seems to be either HPFP, injectors, spark plugs, or coils. I've replaced the plugs and coils so I wonder if should replace the injectors now. Yesterday I bought an extended warranty at the local bmw dealer as well. I just want the problem fixed. Any suggestions?
Old 05-16-2014, 01:53 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Might be sticking vanos solenoids. Remove them and clean with compressed air. Then swap them from intake to exhaust side and vice versa.
Btw the N52 doesn't have the same HPFP issues the N54 has.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 05-16-2014, 02:01 PM
Thanks fdriller9! Good to know about the HPFP as most of the research was on the N54, not the N52. So for the solenoids, do you recommend me using the warranty to fix this or is this something an average DIYfer can do?
Old 05-16-2014, 02:58 PM
wilt wilt is offline
Mein Auto: 2011 328i
...I might be losing oil. I changed the oil a month ago. After replacing it and driving it for a day my level was slightly below the max line. Now its down to the half way point between max and minimum and I smell oil burning at times. Not sure if this oil issue is related to the idling issue.
You could also have a slight vacuum leak, which would result in some leanness of mixture during idle, and especially noticed when the cold engine needs a bit more rich mixture than when running at temperture. The oil leakage could accompany the vacuum break, as well. A cracked valve cover might permit both air leak and oil seepage.
Old 05-16-2014, 03:35 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Vanos solenid. Very easy diy
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
