E46 (1999 - 2006)
View Poll Results: How many miles on your transmission before repairs or replacement needed?
50,000 to 100,000...transmission repaired/replaced. 160 7.70%
50,000 to 100,000...no problems!!! 652 31.36%
100,001 to 125,000...transmission repaired/replaced. 115 5.53%
100,001 to 125,000...no problems!!! 366 17.60%
125,001 to 150,000...transmission repaired/replaced. 90 4.33%
125,001 to 150,000...no problems!!! 261 12.55%
150,001 to 175,000 or more...tranny repaired/replaced. 71 3.42%
150,001 to 175,000 or more...no problems!!! 364 17.51%
Voters: 2079. You may not vote on this poll
Old 03-12-2014, 07:42 PM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
Wow bro how many years of experience do you have rebuilding trannies.
I worked for this cat that opened his business while learning along the way if you know what I mean
Good knowledge skills.
Old 03-12-2014, 09:17 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/05 X5
I built my first transmission 29 or 30 years ago.
The automatics to me are easier than the manuals to build. Well rear wheel drive ones. I do NOT like front wheel drive automatics. The front wheel drive ones are not different as much as awkward to fool with because of the housings. Not to mention r&r'ing them.
Old 03-13-2014, 06:18 AM
lobe29 lobe29 is offline
Mein Auto: 94 bmw 318i e36
Did ZF ever update/fix its d-clutch drum no reverse problem ?
Gday,
I've been reading up on the GM vs ZF tranny and their problems of "no reverse" but with two very different causes, of which i understand.
My question is did ZF ever correct this fault (the d-clutch drum breaking) in any of its later A5S325z transmissions ?
Example - ZF knew about the problem in 2000, and made improvements to this part, hence a trans from say sept 2004 build date would have the improved design, assuming ZF did update / fix the problem.
I know updated replacement clutch drums are available on internet etc, for anyone rebuilding a trans etc but i guess im asking if later model e46 cars eg a 9/2004 325i may have a ZF trans with the problem d clutch drum fixed during its manufacture.
I looked at a tidy 325i 09/2004 but it had the ZF tranny (checked under car. realoem also had it with a zf tranny)
Old 03-13-2014, 10:03 AM
crowz's Avatar
No clue. Ive never looked to see if they updated anything to fix the problem in later models. I know the kits fix the problem but Im not sure if they ever really upgraded the ones produced or not.
Old 03-13-2014, 04:53 PM
crackerlee crackerlee is offline
Mein Auto: 2003 325Ci Convertible
Originally Posted by vlad253 View Post
i have a 04 325i, after 4300 rpms car shifts outa gear then have no throttle control, shut it off and start it, runs fine again? any help?
Had similar symptoms with a Nissan Armada. The transmission ended up being replaced at dealership.
Old 03-15-2014, 01:21 PM
Mein Auto: Passat
Lots of rebuild trannies include a clutch disk And clutch packs along with snap rings a clutch disk package. Although if you rebuild a tranny it does not repair a fuel injection problem or a valve body job.
Old 03-16-2014, 08:56 PM
eykei eykei is offline
Mein Auto: 2000 BMW 328i
177k and running fine. transmission went into fail safe mode (cog with exclamation point inside), but fortunately i found out it was due to me not reconnecting the Mass airflow sensor when I replaced the engine filter
Old 03-18-2014, 02:17 PM
Mein Auto: Passat
Always try to verify that your air flow sensor works properly otherwise you may have your car stall from time to time.
Old 04-15-2014, 02:33 PM
bmw530ii bmw530ii is offline
Mein Auto: 2002 bmw 530i sport
I have a question, my torque converter is slipping. I have 154k miles on my car. How many more miles can I go?
Old 04-15-2014, 02:44 PM
Mein Auto: Passat
If you are trying to adjust your TC you should make sure it snaps or pops everytime you adjust it. It usually takes a bit of patience cause it can get really tricky at times.
Old 04-15-2014, 04:22 PM
I don't know how to work on cars so I can't fix it. I was asking will it interfere with the life of my transmission? I'm hoping to get to 200k miles without any major miles.
Old 05-02-2014, 04:07 PM
Mein Auto: Passat
If you donīt adjust your torque converter to specifications you will lose transmission fluid as you drive it is important to adjust it any transmission specialist can probably fix it quick.
Then again it can also be another problem!
Old 05-02-2014, 04:10 PM
onewish4rmlb onewish4rmlb is offline
Mein Auto:
I'm at 203000 mile runing strong jut replace. Fluid and the tran filter Click image for larger version
Old 05-11-2014, 10:55 AM
1stofMANY 1stofMANY is offline
Mein Auto: e46 330xi
I have 2 e46s, an '01 w/ 206k and an '03 with 265k, both (unfortunately) 5AT. Each of them tight though.
Sent from my DROID RAZR using BimmerApp mobile app
Old 05-16-2014, 11:42 AM
O'E46Lockin O'E46Lockin is offline
Mein Auto: 2004 325i
2004 325i at 140k and recently the shifts have seemed very delayed and rigid never replaced fluid. Starting to think that'd be a good idea
It is not always possible to be the best, but it is always possible to improve your own performance- Jackie Stewart
Old 05-16-2014, 03:20 PM
Mein Auto: Passat
When checking your shifting gears first thing to check it's your tc.
Old 05-29-2014, 03:46 PM
John Davis John Davis is offline
Mein Auto: 2004 BMW 330ci
It's my girlfriend's e46, not mine, but it just quasi-failed at a little over 240,000 miles. We're having it rebuilt today.
2004 330ci w/ sport package, 6 spd manual
Modifications: 3.46 differential, Pedalbox throttle signal amplifier, Active Autowerke performance software, Bilstein HDs, B&M short shifter, Zhp shift knob
2006 650i convertible in stratus gray
Old 05-29-2014, 07:47 PM
Mein Auto: Passat
How much does it cost to rebuilt your engine after 200,000 miles.
Does it feel good to do the job yourself?, or you rather pay to do it.
Old 06-04-2014, 07:30 AM
Tec_Nine Tec_Nine is offline
Mein Auto: 99 BMW 323i
202k original trans, changed fluid before tho
Old 06-04-2014, 12:38 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
This thread is about transmissions, not engines....(but for the record, BMW engines will often go 300K miles without a rebuild...)
The road goes ever onward....
(R.I.P. Jever)
Old 06-04-2014, 09:20 PM
Mein Auto: Passat
Yeah I made a mistake transmission rebuilds last 300k. Wow
" that's quite a number"
Old 06-09-2014, 02:34 AM
Eurobahn Motorsports Eurobahn Motorsports is offline
Regional Sponsor
Mein Auto: BMW's BMW in Greensboro
Automatic Transmission Fluid service Independent VS Dealership prices
Independent shop prices: Parts Included Automatic Transmission Filter Kit10 Automatic Transmission Fluid (ATF) Quarts
Estimate includes:
Labor
$193
Parts (excludes tax & fees)
$156
Total Independent BMW shop price $349
BMW Dealership Prices
Estimate includes:
Labor $247 Parts (excludes tax & fees)
Parts $362 (excludes tax & fees)
Total BMW Dealership price: $609
Best Practices
Your repair shop may recommend a transmission fluid flush, which will require up to 16 quarts of transmission fluid. This will increase the parts and labor price when compared to a normal drain and fill of the transmission.
Common Symptoms
We recommend changing the transmission fluid every 30,000 miles under normal conditions. If the transmission has a filter, that should be replaced as well. If you operate your vehicle under severe conditions (e.g. extreme weather, towing, or a lot of stop-and-go traffic), the transmission should be serviced every 20,000–30,000 miles.
search for a local Independent  BMW greensboro Shop with BMW mechanics that have dealer-level expertise at a fraction of the cost.
Eurobahn BMW MINI Mercedes-Benz Audi
303 S. Swing Rd, Greensboro, NC 27409
Check our website BMW Greensboro
Old 06-09-2014, 10:31 AM
Gafu Gafu is offline
Mein Auto: 325Ci
Just having issues now with my ZF.Replaced valve body and pressure solenoid because 4th/5th were slipping now 1st/2nd slip.
175k miles on tranny,85k on 3rd engine.Dont ask...
Old 06-09-2014, 11:28 AM
crowz's Avatar
Estimate includes:
Labor
$193
$156
Estimate includes:
Best Practices
Common Symptoms
Every 30,000 miles?????????????????????
Thats way to often.
Old 06-09-2014, 05:08 PM
Mein Auto: Passat
300,000 miles itīs okay considering a lot of people donīt look after their tune up intervals.
I like how you guys keep looking after your cars after many years of service.
