Old 05-15-2014, 08:22 AM
WhatDoesThisDo3 WhatDoesThisDo3 is offline
Mein Auto: 330xi
Exclamation Tire and brake questions!
So, when I'm going anywhere past 30mph and I hit the brakes (not slam on them or anything just normally braking) I feel a thumping/skipping feeling in the brake pedal. I had just recently gotten my car back from the shop (Yesterday actually) and today I took it back to have them take a look, they showed me that the inside of my drivers side tire was completely wasted so that was letting a bunch of air out and possibly could be the cause, they also said that I could need new rotors and maybe brakes. So the first question, where would be the best place to buy some new rotors and brakes for the best price? and I'm thinking of doing it for all 4 wheels. Second question, I'm stuck between buying the Conti ExtremeContact DW and the Conti ExtremeContact DWS, I'm here in Maryland and we do get our fair bit of snow and rain so I'm not really sure which tires would serve me best, I wish not to sacrifice any handling/noise if possible! Thanks guys! Oh also, if you have any other tire suggestions I would love to hear them thanks again!
P.S I'm using tirerack.com to look for tires!
Old 05-15-2014, 08:30 AM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
youre rotors might be warped, i dont think it has anything to do with the pads, but i could be wrong.
Old 05-15-2014, 08:32 AM
Mein Auto: 330xi
In order to check if they are warped and to see how much padding is left on my brakes i just remove the wheel correct? Or is it more to it then that?
Old 05-15-2014, 09:40 AM
Fast Bob's Avatar
Keeping it surreal
Yes, there`s "more to it" than that....a good place for you to start would be to read the E46 Wiki, that will educate you a bit.
The road goes ever onward....
(R.I.P. Jever)
Old 05-15-2014, 08:07 PM
sunsetcoast sunsetcoast is offline
Mein Auto: 00 323iT, 99 323i, others
The wiki is your friend.
Nowhere on MD is appropriate for summer-only tires.
And front control arm bushings are probably in your future. Probably control arms too.
Old 05-15-2014, 08:12 PM
Mein Auto: 330xi
Thanks fastbob and sunset, I've got all the information I need from the Wiki, and sunset I hope I don't need those any time soon as I've already seen how expensive it can be to do a replacement on those. All that's left now is to find out where I can get good brake pads and rotors from. Any ideas?
Old 05-15-2014, 09:32 PM
Fast Bob's Avatar
Keeping it surreal
Most guys do pretty well with www.oembimmerparts.com..... as far as rotors go, Brembo, Zimmerman, Balo are all pretty good, getting ones with anti-rust coating already on them will help with keeping them attractive. For pads, Pagid or Jurid are top performers, but tend to dust a bit more than aftermarket pads, but washing your wheels is a small price to pay for brakes that REALLY stop well....
Don`t forget to bed your new brakes !
(R.I.P. Jever)
Old 05-16-2014, 07:51 AM
Mein Auto: 330xi
So I wen't to oembimmerparts.com and found this kit. http://www.oembimmerparts.com/BMW_Br...brakekitsz.htm it contains the pagid pads and zimmerman rotors, would this be the best pricing i can find? Cause I'm doing a brake refresh and changing both front and back brakes along with the brake fluid.
Old 05-16-2014, 10:10 AM
Fast Bob's Avatar
Keeping it surreal
For a complete 4-wheel rebuild you can generally expect to pay around $350 to $400 for kits with corrosion-resistant rotors, so you`re right in the ballpark.
(R.I.P. Jever)
Old 05-16-2014, 11:52 AM
Mein Auto: 330xi
One more question, I was looking at brake fluids and was thinking of using ATE super blue, but read it's been banned? Regardless I know I should use DOT4 fluid but which brand do you guys recommend? Also, I'm getting to order the Conti ExtremeContact DWS from tirerack.com and this little box saying "205/50-17 will not fit on 8" wide wheels. This size requires a minimum of an 89 load index tire." I have stock BMW style 32 rims, would these tires be fine for the rims I'm currently using?
Last edited by WhatDoesThisDo3; 05-16-2014 at 12:37 PM. Reason: Added another question.
Old 05-16-2014, 06:19 PM
Easiest is to pull a wheel and look at the markings stamped on the back.
What size tires are on the wheels now? If they are 8" width, then 225/50-17.
Old 05-16-2014, 08:00 PM
Fast Bob's Avatar
Keeping it surreal
8" wheels will easily support a 235/45/17 tire, which would probably be about the ideal size for that application.
(R.I.P. Jever)
Old 05-16-2014, 08:03 PM
Fast Bob's Avatar
Keeping it surreal
As I wrote above, 235/45/17 would be a good size.
I wasn`t aware that ATE discontinued the Super Blue fluid....try the Super Gold, that`s probably still available.
(R.I.P. Jever)
Old 05-21-2014, 01:19 PM
Mein Auto: 330xi
So I went to the dealer ship to ask what the right tire size was and they said 225/45/17 and I'm looking at tirerack.com right now and I have these all season tires here http://www.tirerack.com/tires/TireSe...45&diameter=17 I really wanted the Dunlop SP sport signatures but they are on back order so I just wanted an opinion on which other of these tires is a good substitute, I'm on the verge on either the Pirelli's or the Good year EagleSports, but any other opinions are greatly appreciated! I wish I could use the Conti Extreme ContactDWS but, they don't have the appropiate size for the car.
Old 05-21-2014, 01:35 PM
Fast Bob's Avatar
Keeping it surreal
There`s more than ONE tire dealer out there....I would shop around for those DWSs, they`re worth it.
And, that suggestion regarding the 225/45/17 size is just that, a suggestion....there`s nothing carved in stone saying that`s the ONLY size you can use....235/45/17s would work just fine.
(R.I.P. Jever)
Old 05-21-2014, 01:39 PM
Mein Auto: 330xi
Do you know of any other tire dealers out there that you can suggest to find the DWS, I looked for the DWS's on tire rack in both 225/45/17 and 235/45/17 and got no results so any other places I could find them? Thanks FastBob!
EDIT: Just found these on tirerack.com (literally just googled 225/45/17 Continental ExtremeContact DWS and they came up) http://www.tirerack.com/tires/tires....um=245WR7ECDWS These should fit correct? The load index is 91W SL though is that fine? Or do I need the 93W XL rating?
Old 05-21-2014, 01:56 PM
Fast Bob's Avatar
Keeping it surreal
How`s THIS ?
https://www.tiresavings.com/tireShop...&sku=303166103
(R.I.P. Jever)
