Old 07-15-2014, 01:48 AM
Themadwelshman Themadwelshman is offline
www.aparryelectrical.net
Mein Auto: BMW E36 328i convertible
Heater only works above 22
Well I've had a scan around the forum and can't seem to find anything specific to my problem.
The short version is no heat come out of my heaters unless I turn the heat up to minimum 22.
Is there an internal sensor or something inside?
1997 523i Touring.
Cheers in advance. Tony
Old 07-15-2014, 06:55 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
what is you outside temp sensor showing as a reading
if that sensor has failed it affects both heat and A/C
Old 07-15-2014, 07:54 AM
Thanks for that mate. Don't know about the A/C as the gas is empty. Getting done next week. But even like that the heaters have worked fine for the last few months that I have owned it.
Old 07-15-2014, 12:29 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
I assume you have the automatic HVAC. If so, there is a sampling fan inside the control panel that allows measuring the cabin temperature. Ensure that it's working: It switches on as soon as you enter the car. Listen at the panel for the fan. If it's not working, the control can't correctly measure cabin temp.
The panel can be removed, and the fan cleaned and lubed. Search the E39 links, at the top of the page, for instructions.
There are two heater cores, each with its own temp sensor.
IHKA diagnostic is via BMW scan tool.
Old 07-15-2014, 01:01 PM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
Ed, does it also use the ambient temp sensor as well?
CCV Delete- So happy about it too
Street Edge Coil Overs
M5 Rear Sway Bar
Hankook Ventus V2 225/55/16
Akebono Euro Front Pads- Awesome
Brembo OE Replacement Rotors- Makes my heart flutter
Stereo Fully Upgraded- Focal, CDT, Soundstream, Kicker
Old 07-15-2014, 02:00 PM
Yes. The outside mirror heaters respond to freezing temps. A -40 will eventually cook them.
My A/C worked very poorly when my ambient temp sensor was damaged. It was probably just working in a dehumidifying mode.
Old 07-15-2014, 03:25 PM
Many thanks for your replies so far. I will have an investigation tomorrow and update as necessary. Sorry took so long to reply myself. Long day at work and fell a bloody sleep on sofa. Haha. Cheers Tony
Old 07-15-2014, 03:26 PM
Just had a thought. Did a new aerial install not so long ago and had the stereo out. Could I have done something then. Think it was around the same time. Not sure? Cheers
Old 07-16-2014, 06:25 AM
sixpot_simon's Avatar
sixpot_simon sixpot_simon is online now
Mein Auto: E30, E39
Yeah, maybe you dislodged a wire while you were in there.
Sounds like something to do with the FSU to me.
