Old 07-16-2014, 07:35 AM
Originally Posted by MuscleWagon View Post
Hey blue, where is the DIY for the auxiliary fuel tank install that allows your E39 to hold 36 gallons?
It's here, found under /how large is the fuel tank in the bestlinks:
- How large is the fuel tank and reserve in the E39 (1)
See also:
- Gasoline: Engine fuel & octane (1) & "The Gasoline FAQ" & top-tier gas stations (1) & Techron additives (1) & how to clean your gas gauge sending unit (1) & mpg calculations (1) how large is the fuel tank and reserve in the E39 (1) & what gasoline to use (1) & how much gas should be left to cool the fuel pump (1) & how to siphon the fuel out of the tank (1) & what is the cost differential between 87 & 91 octane AKI (1)
Old 07-17-2014, 06:22 AM
MuscleWagon MuscleWagon is offline
Fastest to daycare
Mein Auto: '99 540iT/'10 328iT
Old 01-25-2015, 09:01 AM
We should probably make a good list of the colors of the dozen fluids, so that others, who have leaks as shown in this thread updated today, have a head start:
Hmmm... there are only a dozen fluids in the E39.
I'll guess at the colors below:
- Manual & automatic transmission fluid (1) (2) (3) (4) BROWN?
- Power steering fluid (1) RED
- Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1) (BLUE, GREEN)
- Brake & clutch hydraulic fluid (1) BROWN, BLUE
- Engine lubrication, i.e., motor oil (1) (2) BROWN, BLACK
- Air conditioner refrigerant & PAG oil (1) ?color?
- Differential hypoid gear oil (1) BROWN
- Battery electrolyte (1) CLEAR
- Engine fuel, i.e., gasoline & octane (1) CLEAR'ish
- Windshield washer fluid (1) CLEAR, slightly BLUE
- Intensive cleaning system fluid (1) CLEARLY SOAPY
- Air conditioning condensation CLEAR (wet)
If you have a leak, it's one of those.
BTW, what color is air conditioning fluid?
Or, would it always be a vapor anyway?
Old 04-02-2015, 08:00 PM
I was looking up my original vehicle options when I plugged my VIN into this particular VIN decoder, which tells you interesting information about certain fluid volumes and which transmission you originally had:
- BMW VIN decoder (1)
Old 04-03-2015, 02:45 AM
pudl's Avatar
pudl pudl is online now
Mein Auto: E39 530dAT 2001
Time to enjoy some German.
Old 04-03-2015, 06:51 AM
The VIN decoder that gives out the fluid volumes is mostly in English, but I know what you mean, as most of the VIN decoders (which don't spit out fluid volumes) output in Deutsch ...
- BMW 10-character vehicle defect code lookup tool for dealer service records (1) & how to decode your 17-character BMW VIN (1) & the RealOEM parts list based on your vehicle identification number (1) & a list of online BMW VIN decoders (1) (2) (3) (4) (5) (6) (7) (8) (9) & what is the definitive list of electronic computer modules that need VIN recoding once replaced (1)
