Trunk cylinder stuck in horizontal position 540i '99 - Bimmerfest - BMW Forums
Old 07-15-2014, 12:19 PM
yungphillie yungphillie is offline
Mein Auto: 540i
I accidentally locked my doors and trunk, and now I cannot get into my car. My cousin damaged the remote, so I did everything with just my master key. Is there anyway that I can get into my car, please someone help..Click image for larger version
ID:	451853Click image for larger version
ID:	451854 the second photo shows how far it turns
Old 07-15-2014, 12:46 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Use the master key in the driver's door, 90 deg CCW to unlock. Same with the trunk latch. Each may be stubborn from years of disuse. May want to shoot a little Tri Flo into the tumbler beforehand.
When you turn the trunk key 90 CW and remove it places the lock in the Valet mode, where only a master key can unlock the trunk. The glovebox can be secured in a similar fashion by just locking it with a master key.
Old 07-15-2014, 02:10 PM
Mein Auto: 540i
Is there a difference between triflo and wd40
Mein Auto: 540i
And thanks @edjack
Old 07-15-2014, 08:51 PM
rdl rdl is offline
Mein Auto: 530i 2003
WD40 will release frozen parts and displace water to dry things out (handy for wet electrics) But it doesn't provide lasting lubrication.
If TriFlo that edjack recommends isn't available in your area you could look for SuperLube which has worked well for me in locks and similar applications.
Regards
RDL
Old 07-15-2014, 09:07 PM
Originally Posted by yungphillie View Post
And thanks @edjack
Does that mean you got the car unlocked?
Old 07-15-2014, 10:05 PM
Crutzy Crutzy is offline
Mein Auto: BMW 5-series E39
Have people already forgotten how to use a key manually?
Old 07-16-2014, 06:56 AM
Mein Auto: 540i
Thanks I will try!!! My neighbor who happens to be a lock smith got me in the drivers and passengers side, is there a manual release for the trunk?
Old 07-16-2014, 10:22 AM
Read my first post again (show it to your neighbor), and answer my second post.
Old 07-19-2014, 08:12 AM
Mein Auto: 540i
My trunk cylinder is broken apparently. I was able to get in my car and drive to work.
