Old 07-15-2014, 04:31 PM
AV8R4AA AV8R4AA is offline
Mein Auto: 2000 528it 2004 X5 4.4i
Module Masters ABS report
After replacing a defective rear speed sensor and clearing all codes,
The infamous trifecta quickly returned. I sent the module to Module Masters for repair.
I get a call from them that the unit is in perfect working order!
I now am at a loss as what to do or check. My Indy mechanic suggested I send
in the module because it was the original unit.
To make matters worse, I now have a CEL
Any ideas as to what to do or try?:
I love my BMW 528it
Old 07-15-2014, 06:06 PM
I'm confused. Normally, with the exception of a possible (and probably bogus) P0500, there wouldn't be any DTCs with the typical trifecta, so, I'm not sure what you meant by "clearing the codes" or by the CEL lighting up.
What's the DTC?
Originally Posted by bluebee
This "classic" ABS trifecta response is here so I can cut-and-paste it whenever someone asks about it.
(All this information is from teaming up with Bill (540iman) and gathering additional details from BlackBMWs, BMW_n00b13, TheStig, Edgy36-39, Max_VQ, PharoE39, freewilly, BAMF, and others).
Three solid yellow ABS/Brake/DSC lights almost always indicates a classic BMW problem:
1. Go to the first thread in the E39 forums (the VERY best of E39 Links)
2. Search for ABS (you'll find this post)
3. Click on this canonical summary in that post (in addition, see Bill's 'logic' of testing ABS sensors).
Note: The lights may come on all at once, or one at a time, and they may be intermittent, and in the beginning they may go out when you restart the car but come back; eventually they become lit solid all the time. It's all the same problem when you have the ABS Brake DSC trifecta!
Luckily, almost always, resolution is quick, simple, and reasonably inexpensive:
- Quick: In a half hour with a DMM, you'll know exactly what components failed;
- Simple: Removal of speed sensors (<$100 each) and/or the ABS control module (<$500 new) is a ten-minute job each;
- Cheap: My ABS control module rebuild cost me $150 USD, in toto, including tax & shipping (most people report successful rebuilds under $300).
In summary, the flow-chart procedure to follow (summarized from this thread) is:
a. Open the hood, disconnect the ABS control module harness & check the four wheel speed sensors with a DMM;
b. If any wheel speed sensor tests bad, doublecheck at the appropriate wheel; replace the bad one with an OE sensor (<$100, rarely more than one!);
c. If all four speed sensors are good, simply send your ABS control module to BBA/MM/ATE (recommended in that order) for a rebuild ($300-$150 in toto);
d. If the rebuilder can't repair your module (takes about 5 days overall), buy a new module ($480 from Jared at EACTuning) & have the VIN recoded at the stealer (about $120).
In almost all (if not all) ABS, Brake, & DSC light trifecta situations, it's that simple!
BTW, while your ABS control module is out of the car (about 5 days), the following anomalies may occur:
- Brake/DSC/ABS trifecta solid yellow lights (on the instrument cluster)
- Service Engine Soon (SES) solid yellow light lit (on the instrument cluster)
- No ABS (upon hard braking under low-traction conditions)
- No traction control (DSC or ASC on lateral action)
- No speedometer (use a portable GPS navigation unit if you're worried about that)
- No odometer (again, use a portable GPS unit if this bothers you)
- No tripmeter (use a portable GPS unit if it's a worry to you)
- No cruise control
- OBDII diagnostic trouble code DTC P0500, i.e., bad speed sensor (clear by driving or with an OBDII scanner)
- No possibility of passing (California at least) smog inspections (until you replace the ABS control module & clear the DTC)
- No speed-sensitive automatic door locks (if enabled at the stealer)
- No GPS (if you have navigation)
- No mileage calculations on the instrument cluster
- No fuel consumption calculations on the instrument cluster
- No range indications on the instrument cluster
- No speed-sensitive radio (if equipped)
- No speed-sensitive wipers (if equipped)
- Erratic fuel gauge (especially when near empty, so keep the tank at greater than 3/4 at all times)
- Erratic transmission shifting (if automatic; if it bothers you, switch to manual shifting)
SUMMARY:
The problem is usually a single wheel sensor goes bad (wires or the <$100 sensor), or the ABS control module goes bad (a steel resistance-welded wire lifts off its bond pad, Bill kindly ran a full autopsy here). Debugging is best done with a DMM; an OBDII scanner can ONLY find "communication errors", i.e., it cannot tell a bad speed or pressure sensor from a bad ABS control module and will often report the wrong problem because it isn't inserted BETWEEN the ABS control module and the various sensors (see extensive reports by 540iman on this). The ABS control module costs ~$150 to $300 to rebuild, ~$500 to replace; if you put anything back on other than your original ABS control module, the VIN will need to be recoded (15 minutes with a GT-1 or Autologic or similar; impossible otherwise). You'll need to clear your OBDII DTC codes after you fix everything if you plan on passing smog tests that week (ask me how I know). If you need to replace a speed sensor, don't go aftermarket; get as close to OE as possible.
Before you send your ABS control module out for rebuilding, please consider opening it up first, post pictures to Bill's ABS autopsy thread (the rebuilders say they work on previously opened ABS control modules all the time). If you fix the broken wire, post that to the thread as a success story!
This is my very own smog report. Notice that the P0500 was bogus (read the related thread for details).
Old 07-15-2014, 06:43 PM
The DTC WAS
P0500. Indicating right rear sensor failure.
We replaced that, cleared the trifecta lights.
1/2 a block away the trifecta lights came back on.
I sent module in for repair. Status report is works perfect.
Module due back this week. Do I install it and see what happens?
I love my BMW 528it
Old 07-15-2014, 06:51 PM
The DTC WAS
Everything you say confuses me, not the least of which is that a P0500 is decidedly NOT a wheel speed sensor code (see photo below).
It's a transmission output shaft speed sensor code, and, when I had it, it was a bogus code.
In fact, I don't think we have a single case here on the forum of a "real" P0500 (I could be wrong, but, from memory, they've all been bogus).
Anyway, simply typing /p0500 in the bestlinks brings up the following, so I'm just repeating information that is already in the record:
- What's this about the P0500 setting the SES (1) & why you want to wait a week before getting a smog test after removing your ABS control module (1)
Old 07-15-2014, 07:49 PM
16valex's Avatar
16valex 16valex is online now
Mein Auto: 530I/Stick Blown
The DTC WAS
If you are sure the new sensors are good then you should clean the ring ( the hills and valleys are so dirty that the signal is weak causing a bad reading).
Old 07-15-2014, 08:41 PM
BTW, if someone suspects the wheel speed sensors, they wouldn't just replace them, willy nilly, but test them out.
After a five minute test, they'd have a pretty good idea what they were up against...
If a sensor tested bad, cleaning it and running the test again makes sense.
If they still fail any one of the six tests, then I'd replace them.
But not before then ...
Old 07-15-2014, 08:45 PM
alex5er's Avatar
alex5er alex5er is offline
Mein Auto: e39 1997 528i
Did you use OEM wheel speed sensor? Many have experience a return of the trifecta after a day or soon after using aftermarket WSS.
Old 07-15-2014, 09:02 PM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
Joey's links are spam! Do not click them!
CCV Delete- So happy about it too
Street Edge Coil Overs
M5 Rear Sway Bar
Hankook Ventus V2 225/55/16
Akebono Euro Front Pads- Awesome
Brembo OE Replacement Rotors- Makes my heart flutter
Stereo Fully Upgraded- Focal, CDT, Soundstream, Kicker
Old 07-15-2014, 09:48 PM
alex5er's Avatar
Thanks for the heads- up.
Old 07-15-2014, 09:53 PM
Crutzy Crutzy is offline
Mein Auto: BMW 5-series E39
Who is Joey?
Old 07-16-2014, 05:41 AM
helmet75's Avatar
Originally Posted by Crutzy View Post
Who is Joey?
Looks like the mods got the account removed.
M5 Rear Sway Bar
Old 07-16-2014, 10:18 AM
Didn't use Oem.
Might be the problem
I love my BMW 528it
Old 07-16-2014, 05:19 PM
Didn't use Oem.
See also:
- What happens when you use brand new non-OEM wheel speed sensors, by Quick99Si (1)
Old 07-17-2014, 10:24 AM
Richey Richey is offline
Mein Auto: 2001 530i 230k+ miles
Can't tell for sure
from your posts, but it sounds like you got the CEL *after* driving around without the ABS module.
I went a week without mine and got a CEL after just a couple of days. I was almost expecting it since I had no speedometer or odometer while the module was out. I'm assuming the monitoring inputs are all jacked up which flipped a code. After the module was back in, the CEL went off after a few more days.
Old 07-24-2014, 11:43 AM
UPDATE
Installed module today. Same problems. No improvement
except CEL cleared.
Drove car with laptop installed watching wheel speed sensors
speed readout . Front left and right rear reading waaaaay off other
sensors. Swapped front left with serviceable unit.
Test drive same problem.
Right rear is brand new sensor.
Now what??????
I love my BMW 528it
Old 07-24-2014, 11:55 AM
alex5er's Avatar
Did you use OEM wheel speed sensors? Your ABS system is very sensitive. It will reject non OEM WSS. I had tried non OEM sensors on my 97 528i and it did not clear the the worning lights as soon I put in the OEM WSS and drove one block it cleared.
Old 07-24-2014, 01:20 PM
I have the touring. Different than sedan.
Where do I find OEM sensors?
I love my BMW 528it
Old 07-24-2014, 02:50 PM
djmjd djmjd is offline
Mein Auto: e39
I would test all four of the sensor circuits with a multimeter at the ABS module connector. That will tell you if you have a wiring harness issue.
Old 07-25-2014, 01:05 AM
This has always confused me, but AFAIK the (trifecta) warning "clears itself" when you shut off the car.
It checks again when you start the car, so, it would be odd for the warning to last only one block ...
At least that is how I think it works ...
Old 07-25-2014, 06:26 AM
mixz1 mixz1 is offline
Mein Auto: 2000 528i Sport
Re bluebee's comment: I've seen this before and the explanation I got is that it may take x number of rotations for the electronics to call a fault. Not everything is immediately inventoried when the car starts up. I would imagine there are built in buffers for the sensor outputs to guard against setting fault codes when a sensor is momentarily blocked by mud or snow. As to the original poster, from my own experience, make sure you use OEM sensors. The dealer and all the usual suspects like FCPEuro, BMW of Atlanta, Pacific BMW, etc carry the OEM sensors. Sometimes the price differential between the OEM sensor and the knockoff can be eye-watering, but in the end, on our particular cars it is safe to say you must use the OEM part.
Old 07-25-2014, 10:47 AM
I'm not sure where I got the idea that the trifecta resets itself at ignition cutoff, but, it was so long ago, that I'll accept any explanation at this point.
So that the OEM information isn't lost, I'll append it here, so others find it when they're looking up which parts should always be OEM:
- What brand is the OEM original equipment manufacturer for your BMW parts (1) & what parts & supplies are best to buy OEM, OES, or OE (1)
Old 08-05-2014, 09:39 PM
I ordered 2 OEM sensors.
One for suspect right rear, one for suspect front left.
I did the diode check and although my DMM was acting weird, I got a bad
test from said sensors.
My right rear was replaced with a PEX brand and front left was swapped for supposedly
serviceable sensor.
Fairly confident 2 OEM sensors will fix my trifecta.
Module masters report card was A+, so that isn't my problem.
I love my BMW 528it
Old 08-05-2014, 10:22 PM
alex5er's Avatar
Please post you results to validate the uses of Only OEM wheel Speed Sensor on all E39 (especially early E39) hopefully others don't have to spend money, time and use parts that are not compatible. ( I also had to learn the hard way.)
I wish we can count how many bi/trifecta were solved just by using OEM WSS as directed by thousands of post. Especially on early E39 build before 08/1998 with the ABS T/C module in the car, not under the hood.
Treat your E39 with respect and Run It Hard !!! every chance you get.
Old 08-09-2014, 03:38 PM
Installed bmw factory part.
Problem fixed.
No more lights !
Did the right rear only.
As others have said 'THIS IS A DEALER ITEM ONLY'
learned my lesson on this one.
My defective (brand new PEX brand) didnt
work for more than a city block.
DO NOT BUY AFTERMARKET WSS.
I love my BMW 528it
Old 08-09-2014, 05:02 PM
alex5er's Avatar
Glad to hear your problem is solved.
