2011 Non Idrive X1 - Bimmerfest - BMW Forums
Old 07-31-2014, 04:10 AM
mike_14 mike_14 is offline
Mein Auto: Car
Smile 2011 Non Idrive X1
Dear All
Greetings to all of you
I am planning on a BMW X1 . Year 2012. This is a non-Idrive model so there is no navigation, reverse camera, etc...
want to find out whether a multimedia setup with video and navigation can be fit in without affecting the BMW look and feel
I did a search but the results were not found
thanks a million
cheers
mike
Old 07-31-2014, 06:46 AM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
Its been done before.
This guy has a nice post about it.
http://bmwdvdplayer.wordpress.com/20...-installation/
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 07-31-2014, 06:51 AM
aekdbrich aekdbrich is offline
Mein Auto:
Originally Posted by mike_14 View Post
Dear All
thanks a million
cheers
mike
Well anytime that you make a change to the interior of a BMW, you will change the natural charm. That being said, I have seen the mod done very tastefully, and also very poorly. It just depends on what you will be adding and how you will install.
I wish I knew where I saw the writeup of an E84 owner adding the screen and nav into the dash in the storage compartment where the screen would go for stock iDrive. He even added a controller similar to the iDrive interface behind our shifter. It looked good, however it wasn't something that I would do personally. But, it's personal taste and it wasn't an eyesore.
I'm pretty sure it wasn't a kit and he had to do some of his own fabrication work too in order to fit the screen in, so that's a consideration in your planning as well.
Hope this helps and good luck should you take on the project!
2014 BMW X1 sDrive28i "Black Betty"
2013 Mini Cooper S Countryman "Penelope"
2011 BMW 328i "Heidi" (past)
Old 07-31-2014, 06:58 AM
Mein Auto:
Nice find Stone. Nope, that's not the one that I saw. The OP may be in luck! That doesn't look bad at all!
