3.0SI Spark Plugs Engine Fail - Bimmerfest - BMW Forums
Old 07-15-2014, 07:51 AM
GermanEngineerd GermanEngineerd is offline
Bimmer enthusiast
Mein Auto: 08 x5 3.0si
Unhappy 3.0SI Spark Plugs Engine Fail
Hello All,
Recently I wanted to change my spark plugs at 91k. My car was running well the night I parked it. the next morning I went and unlocked the car, then proceeded to perform my maintenance per the DIY on the forum for x5s. I also looked at youtube to visually ensure my method. I successfully replaced all of the spark plugs and placed my coils back in firmly ensuring contact with the plugs.
After I reassembled all the components including MAF sensor and coil harness connections. I went to start the car and it would not start at all! it would hit and miss nearly on every cylinder! I went and replaced my old spark plugs and confirmed the process. I went to start and same issue!!!
I have fuel, air, and seemingly no spark!
Does this mean al the coils died at once?!?!!? I was hoping to avoid the major cost of coils for the next pay period.
Please Help!!
Old 07-15-2014, 09:03 AM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
I start off by saying I'm entirely unfamiliar with your engine, but on our Z4 there are a few ground straps between the coils and the valve cover. There's also a couple of grounds from the harness to the valve cover.
Could it be you maybe removed them and forgot to put them back?
Old 07-15-2014, 09:06 AM
Bimmer enthusiast
With this engine, there is no need to remove the ground. I am familiar with the method of removing the ground on the z4 engines and on my 328i.
Old 07-15-2014, 02:32 PM
lordshin808 lordshin808 is offline
Mein Auto: X5 4.8
did you get this figured out yet? I'm in Houston too, and was planning to changed the spark plugs on my 4.8i this weekend.
Old 07-15-2014, 02:57 PM
Bimmer enthusiast
I had to tow it to eurocarwerk, they will take a look on Thursday or Friday as they are booked. I'd advise if you haven't replaced the coils to replace those at the same time.
Old 07-15-2014, 03:13 PM
ard ard is offline
Resident Curmudgeon
Well, whatever you do..DONT let OP help you!
(I kid, I kid... )
Sorry to hear- I am not familar with this motor, but I had ONE bad coil that caused misfires on multiple cylinders on an S62...very odd. Also, the coils plug into the harnesss individually, and screwing up one of those- or pulling the harness loose could cause this. Id look at the harness/connectors... (i guess you alreaady did this 20 times, eh?)
Let us know what it winds up being. I find it hard to believe all coils died at once. But I am sure if you told the shop you think it is the coils they will agree with you....$$$$
GL
Old 07-15-2014, 03:45 PM
Mein Auto: X5 4.8
i thought coils rarely fail. I I replaced 2 sets of spark plugs on my E46 and was still on the original coils when I sold the car at 175k.
Old 07-16-2014, 11:19 AM
ard ard is offline
Resident Curmudgeon
In general I agree with this.... however, some car/coils do have high failure rates- the Beru's on the 996TT for example, as OE parts, usually start failing after 50k, 6 years. (heat was a btich on this application) But rarely do you see multiple parts fail simultaneously....one here, one there... plus the whole 'not start' thing is odd for a coil failure.
Not to be overlooked: one bad coil can cause misfires that- based on how the engine computes timing and faults- can show up as multiple misfires on other cylinders. This was on an S62, so older technology..a pita to narrow down. Just an FYI for people looking to troubleshoot down the road. I had 4 or 5 fault codes, all different cylinders... replaced one coil, perfect.
Old 08-08-2014, 08:48 AM
Bimmer enthusiast
Sorry for the late response everyone, hard to come back from a $1,500 hit...
Replaced all coils (some how they could not identify just one)
Replace Battery
My wallet is crying...
