E34 (1989 - 1995)
Old 05-15-2014, 04:28 PM
Trickyricky83 Trickyricky83 is offline
Mein Auto: 1990 BMW 525i E34
Exclamation Clutch Kit Replacement
Hi my name is Rick,
I have a 1990 525i E34 and the clutch went out on it I was just wondering if anyone had any suggestion and or tips when i go to replace the Clutch Kit. I recently helped my uncle replace a clutch on his 74 Ford F-150 and I'm hoping that this Clutch replacement isn't nearly as a pain in the butt as it was on his truck. Please lemme know as i am doing this tomorrow morning and going to start prep this eve. Your advice and opinions would be much appreciated. Please and Thank you in advance
Old 05-16-2014, 04:52 AM
south26 south26 is offline
Mein Auto: 535i 1989
get the Bentley
Old 05-16-2014, 05:26 AM
I wish I could afford one of them but that's just not possible lololol an I've already commuted to my BMW. It's probably the first new clutch it's ever had considering it's used and only had 147,000 miles on it when I purchased it. It now has 167087 I out 20,000+ miles in just over a year!!! I drive a lot and love my BMW!!!!
Old 05-16-2014, 08:27 AM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
There is an electronic version of the Bentley in the bible in my signature.
It is FREE
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 05-16-2014, 08:34 AM
Solidlifter Solidlifter is offline
Mein Auto: 90 535i, 95 525it, Q45a,
I have done the clutch on e34 535i, which got me scratching my head a bit with the bolts on top of the bell housing. The best tip I can give you is loosen the the motor mounts and drop the engine as low as possible (I.e. tilt the engine) to get better access to the torx bolts at the top. Now the 535i has an m30 engine which has the longest block (guessing) so I had to do this in order to get access to the bolts (They should be 10 and 13 torx). m50 is a shorter block (again not sure, just by comparing 2.5 to 3.5), so you might be able to get access without lowering motor. Got way with it on an M42. Ease of removing the tranny depends on the length of the block. Bentley does not say anything about lowering the engine. Long extensions and wobley's won't be a bad idea. BTW watch out for the bolts holding the pressure plate, they are Allen heads and are real easy to strip if they are been on that long.
Old 05-16-2014, 08:49 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Unless that Ford was a 4X4 I cannot think of an easier clutch job. You'll not enjoy the BMW's integral bell housing. Fortunately the whole gearbox is only about 70#.
looong extensions are your friend when removing the trans bolts. Be SURE the clutch disc is properly aligned. Get yourself some extra bolts with the heads cut off to serve as alignment pins when re-installing the trans. Chamfer the ends and cut a groove so you can back them out with a screwdriver if they bind.
Dropping the exhaust is the most objectionable part for me here in the rust belt.
Enjoy!
Take my advice, I'm not using it.
Old 08-10-2014, 01:58 AM
Thanks for all Y'all's help I really appreciate all that info. I know it's been months since I've replied my bad. Had a couple month vacation that came worth free jewelry any who I've been busting my butt in trying to get this done ever with a supposed master mechanic we are stuck. I cannot get the clutch to shift transmission into gear. Yes it was my first time bleeding a hydraulic clutch and pain in my ass figuring it out but still won't do anything. Any suggestions?
