Old 06-16-2014, 08:31 AM
Imcochrane Imcochrane is offline
Mein Auto: 2003 m3
Trouble code P2062
Hi guys, had this pop up yesterday, cleared it and up it came again, P2062 - Reductant/Regeneration Supply Control Circuit/Open, any ideas? It's a 2009 x5 3.5d with 178,000kms, thx guys
Old 06-16-2014, 10:10 AM
ard ard is offline
Resident Curmudgeon
Any history with you car?????? Massive issues with the 2009/2010 units, with multiple recalls, software, parts, etc... Confirm that all the prior SIBs/updates were completed.
Based on a first pass, you might have a broken wire, loose connector at some point on that circuit. Get a schematic and find the connecotrs/cables and check each one. If those are good you might have a bad DEF tank control? Just guessing on that as I dont have schematics here...
ALSO- I assume you have searched here and elsewhere for P0262..yes?
Old 06-16-2014, 10:23 AM
Mein Auto: 2003 m3
Yes I've been searching everywhere for the p2062 code, no luck
Old 08-02-2014, 02:43 PM
Mein Auto: 2003 m3
Ok I ended up taking it to bmw, really nice mechanic there tested it for me, gave me schematics, told me the metering valve was pooched, just put a new one in and for the first time in months the check engine light is off!! Yay!!
Old 08-05-2014, 07:43 PM
pppininfarina pppininfarina is offline
Mein Auto: X5
Hello
I have a 2013 BMW X5 E70 with 4200 miles the check engine light comes on.The trouble code is P2402 evaporative pump but the car still working ok ... only the check engine light is on....iI still driving till 8k miles but the light doesnt turn off...I have to erase the code to see if the the check engine light turn on again or its supose to turn off by it self?.....the gas cap appear and clicks ok....somebody can tell me whats going on ....or how to fix it?.....please thanks
Old 08-06-2014, 06:06 AM
Hd2000fxdl Hd2000fxdl is offline
Mein Auto: 2011 X5
Originally Posted by pppininfarina View Post
Hello
While I like to know as it seems you do to know what the possible or actual problem is before it's serviced but an 2013 with that mileage is under warranty right?? Being that it is, hell I wouldn't really care as long as it fixed and fixed right.
Harry
Old 08-06-2014, 10:39 AM
ard ard is offline
Resident Curmudgeon
^^ Good call.Sounds like the light came on at 4200 and he drove it to 8000. At 8k and a 2013 it is surely under US/BMW warranty.
Unless...the car is out of the country and his "Nevada" is a very, very far south "Nevada"....
Old 08-06-2014, 12:31 PM
ninja_zx11 ninja_zx11 is offline
Mein Auto: 2009 X5 35D
i would suggest you to use bmw rheingold or inpa or DIS to diagnose BMW vehicles to get proper info regarding fault code.Are you using generic scanner?
Old 08-12-2014, 07:12 PM
Mein Auto: X5
Thanks everyone.....I took the car to the dealer (its under warranty)and they replace the evaporative emission pump under the Right Rear splash shield 'PUMP FAIL'....and they erased the code....so my questions is.....How long the new pump will be alive....its a Brand new BMW with china parts?.....is supose that thing happens with the GERMANY DRIVING MACHINE? I still loving the car so....will see what else coming up....thanks again for your help
Old 08-12-2014, 07:17 PM
Mein Auto: X5
I was in FLORIDA east coast when the PUMP fails....so so far away from home.....google it
Old 08-12-2014, 07:50 PM
ard ard is offline
Resident Curmudgeon
Should get you back to Nevada, easy.
