E34 (1989 - 1995)
Old 08-10-2014, 08:47 PM
Sweet16FirstCar Sweet16FirstCar is offline
Mein Auto: 1989 BMW 525I
Exclamation 1989 525I Electrical Shut Down
I was driving the BMW home tonight, slowed for a stop light and all the electricity just went away to include the engine simply quit immediately. Everything just shut down instantly, Lights, Engine, all of it so coasted into a parking lot and had the car towed to the house. I have tested the Battery and it is fine, replaced it and the alternator about a year ago. This was without any warning, all electrical is simply just gone with no signs of life. Any help is appreciated. I checked the small fuses and all are fine.
Old 08-10-2014, 10:14 PM
BMWFatherFigure's Avatar
Old School
Check all battery cables, terminations and connections. Then move on to major feed wires.
Current:
E38 Parts Car
Previous:
Old 08-12-2014, 03:11 PM
Red face Problem Solved
Thanks for the advice. I was a bit nervous when I saw the complex wiring but found the problem. There is a smaller positive lead coming directly off the positive battery terminal connected by a small bolt. It runs to what I will refer to as a fusible link. One wire goes into the small black case located just behind the battery on the passenger side of the car. Two wires come out and inside there is a piece of thin metal used as a fuse. That piece of metal had broke and when I connected the wires directly, PRESTO, the car had full electricity. It appears that one link controls electricity to the whole car. I really hope this find helps others. Very simple fix and I will order a new component so I can have the fuse back in place. Take care all.
Old 08-12-2014, 07:44 PM
south26 south26 is online now
Mein Auto: 535i 1989
http://www.bmwe34.net/E34main/Mainte...sible_link.htm
Yep that is the fusible link.
Andy
