Old 08-15-2014, 07:16 PM
DMAX745i's Avatar
DMAX745i DMAX745i is offline
Mein Auto: 2013 750xi & 2002 745i
Originally Posted by Paulzv9 View Post
I couldn't find the pricing and where to buy them from. for my 750I xDrive WITH air suspension on the rear.
http://www.bimmerfest.com/forums/sho...d.php?t=706480
Check this thread. These guys are able to get them. Im in canada so id assume distributorship would be different
DMAX745i
Old 08-15-2014, 07:21 PM
DMAX745i's Avatar
A/C schnitzer kit
Attachment 458685
Rear shot
Originat A/Cs trunk and roof wing
DMAX745i
Old 09-22-2014, 04:57 PM
mbworldz mbworldz is offline
Mein Auto: 2011 740i Blk/Blk
Wow so details. I only hide my pedal box under the floor mat.
BTW i got a question of the ashtray coin holder. For some reason all in a sudden after the car wash, I can't open it. Not sure if there is a coin stuck there. Brought the car back to the car wash but he denied. It was working fine but i am sure he doesn't want to take the blame.
Do you know how do I get access to that and fix the problem ? Any hint will be great. Thanks
Originally Posted by aom View Post
Couldn't stand the fact that the Pedalbox install basically leaves it (and wires) dangling out in the open. Looking at my car, I realized I could run the wiring under the carpet, behind the side console trim and mount the remote in the ashtray holder. This allows me to close the ashtray cover and completely leaves the install unnoticed. Also I don't use my ashtray, so it was nice to get some use from that space.
Basic install was to:
1) Remove center wood console. Remove panel under driver's side dash (which includes the knee airbag.) Remove driver side trims from center console (carpet and leather trim). Remove Accelerator
2) Fish BMW throttle wire behind carpet. Fish PB cables behind carpet and connect, then pull the PD throttle cable through the carpet to connect it to the throttle. Connect.
3) Run the PD cable along the edge of the center console and down into the center console. Lay the remote control in the ashtray. Notice the little cutout in front of the ashtray where I ran the cable through, it was already there from BMW (maybe they knew this was going to happen)!
4) Screw everything back, pop the center console back in place, slide all the trim back on and use some doubled over double sided 3M foam tape to get the remote to the correct height and tape it.
Observations:
The Ashtray light nicely lights up the remote (plus with the built in light on the remote and the slow opening ashtray, it's inspiring!).
I could now do it in about 15-20 minutes. Took me originally about 30min since I didn't know how things were mounted.
The install is very flush, there is no interference with panels or trim pieces (so nothing juts out or buldges out).
Old 09-23-2014, 10:24 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
Sorry, I didn't personally need to remove the ashtray door, so not sure how it's done.
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 09-24-2014, 08:04 AM
BMW7XAudi BMW7XAudi is offline
Mein Auto: 12 750LiX
I have had this problem in another car. I just tapped it a few times and it opened. I good quick tap might do it.
B
Old 10-16-2014, 07:10 AM
ptoscano ptoscano is offline
Mein Auto: 2012 750 lix-
Do you remove unit when going to dealer ? For warranty purposes ?
Old 10-16-2014, 10:15 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
I do not remove it when I go to the dealer. My dealer has not yet commented on it.
Old 04-26-2015, 06:36 PM
sandflee sandflee is offline
Mein Auto: 2008 535xi
how do i remove the center console
I am trying to do the stealth install of pedalbox, but I having such a problem trying to remove the center console. I was able to remove the two screws, but cannot get the console to pop out.
Can any one help me with some picture? I did buy plastic pray. Thanks bunch.
