Old 08-17-2014, 11:45 PM
KhaosKevin KhaosKevin is offline
Mein Auto: BMW X-3
2005 X3 2.5 4X4 light
My 4X4 light is illuminated in my cluster and I have the DSC system--does this mean I have an issue with the DSC, or is it indicating it is off? I depressed the DSC button and it won't eliminate the light. I was told that I may off depressed the button when I was detailing the dash area. I didn't have any issue with the light until I subsequently cleaned the interior. On top of it I now have a SES light. Please help, thanks.
Old 08-18-2014, 04:52 AM
timarnold timarnold is online now
TA
Mein Auto: 2003 bmw 525i, 2005 X3
Get the MIL codes read and see what you get. Could be the gear in the transfer case actuator or a wheel speed sensor or a number of other things.
Old 08-18-2014, 08:35 AM
Mein Auto: 2004 X3 2.5i
If you spent a good amount of time detailing with doors opening and closing, and radio on, the battery could have run down a bit. Then on starting up, DSC processor gets confused.
Usually goes away after the next restart, provided battery is healthy. If not, BMW-specific scanner required to see what codes triggered.
SES light being on must be a separate issue that surfaced now as a coincidence. Vacuum leak most likely. Standard code reader needed for that.
Or was the engine shampooed as part of the detailing?
Old 08-18-2014, 09:05 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Really you can't guess what the lights mean. If you want to check the lights yourself buy the code reader in post 2 here. http://www.bimmerfest.com/forums/sho...errerid=343410
As above if the battery went flat it will have dumped all the calibration for the wheel speed sensors and should relearn them by the end of the road; restarting the car should extinguish a light lit for that specific reason.
Old 08-18-2014, 10:24 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Try turning he steering wheel all the way to the left and then all the way to the right, full lockout positions. That may reset it...
Old 08-19-2014, 04:59 PM
Mein Auto: BMW X-3
Thanks for all your responses. I took my X3 into my mechanic, hooked it up and he said nothing was wrong. He seems to think when I washed it, I wet the engine with the jet spray onto the lenses, which I cleaned too and got water on the cylinders. After I washed the vehicle, the EML light came on, then about three hours later it turned off due to the vehicle being dry. I had the oil changed too, because the previous owned informed me he used conventional oil. So, all systems go, thanks again.
