Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 08-21-2014, 06:55 PM
mattycb mattycb is offline
i3 Driver
Mein Auto: BMW i3
DC charging at home?
Did a quick search and didn't see this question answered elsewhere. If I missed it, my apologies.
Is there any option to install a DC charger at home? There are no public DC charging stations in my general vicinity (outside Chicago). I know the level 2 charging stations can be installed at home but I don't see anything about DC from a cursory Google search.
Any ideas?
Matt
Vroom vroom
Old 08-22-2014, 02:58 PM
Boatguy54 Boatguy54 is offline
Mein Auto: i3 on order, Mercedes E
I suspect it would be fairly expensive as you'd need to have the rectifiers that convert AC to DC in your home charger and those generate some heat which must be dissipated. A regular EVSE is just a glorified switch with some logic to manage the control signals between the car and the EVSE. A DC charger is actually transforming the electricity.
For an i3 I think the advantages would be minimal, but maybe I don't understand your need.
What prompts the interest in a DC charger?
Old 08-22-2014, 03:53 PM
Here is a DC charger for home use: Electric Motor Werks
Old 08-22-2014, 11:06 PM
i3 Driver
Mein Auto: BMW i3
Thanks Boatguy.
The reason I asked is that the i3 charges to about 80% from empty in 30 mins on a DC charge (provided the i3 is equipped with the DC fast charge feature which mine is).
Thanks again for the link. I'll check it out.
P.S. You're blessed because I believe California is one of the only states in which BMW is rolling out DC charging stations.
Matt
Vroom vroom
Old 08-23-2014, 07:13 AM
ktagly2 ktagly2 is offline
Mein Auto: 2014 BMW 328i xDrive
Be careful, BMW has hinted to the fact that regularly charging on a DC Fast Charge could damage the battery. Although I'm sure if you're leasing that won't matter...
Old 08-23-2014, 08:20 AM
Could you please direct us to where/when they've made those comments?
Old 08-27-2014, 09:27 AM
jimmsters jimmsters is offline
Mein Auto:
When BMW gets more in North America, it will be a $6,500 option not including installation.
Old 08-27-2014, 12:21 PM
Sorry I'm missing the context on this. What will be a $6,500 option?
Old 09-01-2014, 04:34 PM
bimmer_fam's Avatar
bimmer_fam bimmer_fam is offline
Mein Auto: '13 328i, '13 Chevy Volt
Just curious, why would you need DC fast charging at home? It's just not practical from infrastructure cost perspective IMO (besides the cost of the actual station, you most likely would need new service to your residence to provide the Amps necessary to use the DC fast charger). L2 home/work charger should do the trick in 90% of scenarios, plus you can cover another good percentage with public stations, and don't you get a "rental" ICE powered car use from BMW with i3 deal?
Chevy Volt (600+ MPG to date)
MY2013 328i (wife's new ride)
Retired:
ED2010 - MY11 328i SpaceGray/ChestnutBrwn, Premium, 6MT 05/06/10, re-delivered 07/24/2010
2010 Audi A4 Quattro
ED2007 - MY07 328i SparklingGraphite/Blk, ZSP, 6MT, 6FL 06/01/07, re-delivered 07/23/07
2007 X3si
2004 325i
Old 09-21-2014, 12:27 PM
bayarea2007 bayarea2007 is offline
Mein Auto: 2009 335d; 2014 i3
anyone knows the power efficiency comparison between DC, L2, and L1 charging methods?
Old 09-21-2014, 12:35 PM
What do you mean by efficiency?
Converting from AC to DC is not 100% efficient whether it's done inside the car (i.e., L1 or L2) or outside the car (DC Fast). Really specific efficiency is going to be a function of the design of the converter. They aren't too sophisticated, really just a big solid state rectifier.
In terms of how much total energy is taken from the power grid to charge the battery I doubt there is a material difference between the three methods and all will be in the range of 80-90% efficient.
Old 09-21-2014, 01:02 PM
I think you answered my question, 80-90%. I was more interested in L1 and L2 comparison simply because you would need to pay extra to set up L2 station at home. Assuming charging time is not a big issue at home, I would choose the system that has better power conversion efficiency.
My commute is 35 miles round trip so overnight with L1 is sufficient to cover that range. Sounds like there is no advantage for me to get L2 for my house.
thanks!
Old 09-22-2014, 07:28 AM
ultraturtle ultraturtle is offline
Mein Auto: 2002 325iT, 2007 325i
The most efficient DC to DC converters on the market can reach efficiencies in to the mid 90% range, but for a wall to battery comparison with AC EVSEs, you have to factor in the typical 85% efficiency of the AC to DC conversion, for 81% efficiency at best.
The EPA measures wall to battery efficiency for the i3 at 85%, but we do not definitively know whether they use an L1 or L2 EVSE in their testing. 85% is a widespread observation for L2 EVSEs, however.
Some folks have measured 81% efficiency from their L1 EVSEs.
From an efficiency perspective, L2 EVSEs are probably your best bet.
Old 09-22-2014, 09:30 AM
So I guess the question is how long would it take to recoup the cost of an L2 charger if the savings is 4%? At a nominal PG&E (Northern California) rate of $.20 / kWh, I calculate it would take more than 15yrs to recoup $1,000 for an L2 charger and installation.
If an L1 charger will do the job, no reason to spend on an L2 charger.
Old 09-22-2014, 10:23 PM
Agree, not worth it for me to install L2. Fortunately the only fast DC station offered by ChargePoint in NorCal is 5min away from me. I think I'm covered in case of emergency
Old 09-24-2014, 08:59 PM
bimmer_fam's Avatar
There is (or at least was) a CA state rebate that essentially covers cost of most (reasonable) L2 EVSEs as well as most installations.
But yeah, if you are able to recharge with L1 overnight, it covers probably 90%+ scenarios of EV ownership. Savings are obviously not in efficiency of L2 over L1, but in faster charge times and ability to schedule charging during grid "slower" hours with lower costs where applicable.
Retired:
2007 X3si
2004 325i
dc charging
