Old 08-20-2014, 04:22 PM
bimmer_boii_E38 bimmer_boii_E38 is offline
Mein Auto:
Multiple problems!!help!
So on my 97' 740il I've had the battery light on for maybe 2 days max and Sunday night will driving the interior lights where kinda blinking and the radio when off, car continued to drive but once I stop and turned it off it said "Trans fail prog" then tried turnig it back on and it was clicking as tho if battery was dead but I could still lock doors ect. Well it started an hour or so later that night. Now it continues to do this problem ohh and when it happens battery light is on abs light and traction control goes on as well I need to no what it could be! Maybe the f-100 fuse in the trunk blew idk plz help me this is my first bmw at 17 and I love it and would hate to not be able to keep this car alive!
Old 08-20-2014, 04:34 PM
Mein Auto:
Ohh and there no werid noises or grinding in the tranny
Old 08-20-2014, 04:41 PM
Mein Auto: 1999 740i
It acts like your battery is dead/dieing because it is. The problem is your alternator. Its not charging the battery enough or not at all. Go to test 9 on your display and see what the volts are. it should be about 13.4v or more.
Battery light on indicates its not charging, aka your alternator is not putting out. All the other symptoms you describe is a byproduct of your battery not having enough juice.
Being a 97 your kind of lucky. You have the air cooled cheaper one opposed to the water cooled one that started in 99.
NAPA has rebuilt Bosch alternators with a lifetime warranty for about $300.
Goodluck
Old 08-20-2014, 04:47 PM
Mein Auto:
Thanks! How should I check the alternator tho O.o
Old 08-20-2014, 04:55 PM
Have you unlocked your OBDII?
Old 08-20-2014, 04:57 PM
Mein Auto:
As in pulled the cover off and used it yes but I don't have a moniter with me and now the car won't start at all but when I turn the key lights on dash light up and will stay on but just won't start
Old 08-20-2014, 04:59 PM
Check your messages....I just sent you something
Old 08-21-2014, 10:02 AM
BMWFatherFigure's Avatar
Old School
Battery dead.
Current:
E38 Parts Car
Previous:
Old 08-21-2014, 10:04 AM
Mein Auto:
Originally Posted by BMWFatherFigure View Post
Battery dead.
It is a dying alternator
Old 08-21-2014, 05:42 PM
Any updates?
Old 08-21-2014, 05:50 PM
Mein Auto:
Originally Posted by JasonSC540ia View Post
Any updates?
I'm buying a brand new alternator this weekend and a new accessory belt since I'll need to remove anyway to get to alternator. I'm planing on doing it my self, and use my Bentley and the help on the internet I'll keep you posted on the day that I do it and complete it
Old 08-25-2014, 12:32 PM
Mein Auto:
Hey guys what amp alternator do I need for my 1997 740il when I'm on bavauto they have to choices 120 and 140 which do I get? Can't find this info anywhere
Old 08-25-2014, 01:15 PM
miguel740i miguel740i is offline
Mein Auto: 1995 740i
140 amp
Old 08-25-2014, 01:16 PM
Mein Auto:
Thank you!
Old 08-31-2014, 10:54 AM
Fixed?
Old 08-31-2014, 02:36 PM
Mein Auto:
In the process! Click image for larger version
Old 08-31-2014, 04:42 PM
Mein Auto:
Do any of y'all no how to get it out of the engine area...I've been at it for an hour an have had no luck or vids in internet
Old 08-31-2014, 09:34 PM
tomloans tomloans is online now
Mein Auto: 2001 740i Sport
This guy has it down pat...
http://www.bimmerfest.com/forums/sho...d.php?t=793318
Old 09-01-2014, 05:21 AM
Mein Auto:
I've seen this...lol but I haven't removed any of that extra stuff and did exactly as my Bentley described it's just a bitch to try and get out once disconnected and all that
Old 09-01-2014, 09:13 AM
Jack the car up and take it down from under neath
Old 09-01-2014, 11:23 AM
Mein Auto:
Not possible and it already is I'll send pics of me trying to get it out soon
Old 09-01-2014, 02:37 PM
Mein Auto:
No luck this weekend...I'll have to try later in the week
Old 09-06-2014, 06:50 AM
Sorry, just saw your PM. Have you tried dropping the alt through the bottom of the car?
Old 09-06-2014, 10:12 AM
Mein Auto:
I can't not enough room...but I'm going to pep boys today to rent a fan/radiator removal tools...seems like removing that is the only way to replace it it will be done today tho!
Old 09-06-2014, 12:12 PM
If I were u I would follow the video I sent u. It is just easier to get everything out of the way... U can then change out pulleys belts thermostat hoses fan and fan clutch... Change the seals on your vans solenoids etc... Just do a nice clean sweep so when u put it back together it is all new and good to go
HTML code is Off
