2000 BMW 740il engine swap - Bimmerfest - BMW Forums
Old 08-07-2014, 05:27 AM
ucme2222 ucme2222 is offline
Mein Auto: 2003 BMW 740il
First hello everyone , have just joined and think this the best forum ,have checked it outand like what i see ,so i joined .
My question is i have a 2000 BMW 740il and need to know what i need to change to install a 1998 BMW740il engine in my 2000 BMW 740il , what changes do i need to make to make this engine run right ?
thank you all for your help!
ucme2222
Old 08-07-2014, 02:50 PM
AutohausAZ-Mike AutohausAZ-Mike is offline
Past Sponsor
Mein Auto:
Welcome to the forum!
Edited.
AutohausAZ.com
Old 08-07-2014, 03:19 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest! I've moved your question over to the E38 7 series forum, you'll get more help in here.
Tim
Old 08-07-2014, 03:57 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
The 2000 model and the 1998 are both the same M62 engine.
AutohausAZ.com
Incorrect. The 99 and up have the vanos M62TU. Many differences with the modules. I would HIGHLY recommend getting an engine from a 1999-2001.
Old 08-07-2014, 04:11 PM
Past Sponsor
Mein Auto:
You are correct.
The 96-98 is M62B44
The 99-01 is M62TUB44 had the Vanos system added.
Old 08-07-2014, 04:32 PM
2000 BMW 740il engine swap from a 1998 BMW 740il
Thanks for the info ,but there isn't anyone who has done this swap ? And if i really want to try this does anyone have any good advice to do the swap ?
Old 08-07-2014, 04:34 PM
anyone have the knowledge on swapping a 1998 BMW 740il engine into a 2000 BMW 740il ?
any advice ?
Old 08-07-2014, 04:48 PM
I personally have not seen anyone do it after finding out what all is involved. You would need the wiring harnass, DME, EWS, key, ignition, aux fan, accelerator pedal (I believe), among other things from the donor car. I am sure there are many things I am not thinking of. Then there is the coding after it's all in. The engine itself will fit right in but there are so many differences in the set up electronically. Hopefully someone here can give you better info.
Quick search found this:
http://www.bimmerfest.com/forums/sho...d.php?t=684313
It's the reverse of what you want to do but gives you an idea of what you are up against.
Old 09-01-2014, 04:21 AM
Question 2000 bmw 740il engine cut off and no re-start
well thanks for the info and yes i purchased a 2000 4.4l engine, New question is , car was running and shut off and would not restart and sat for months, no codes stored , battery was dead ! what would cause the car to just shut off, fuel pump, cps sensor or cam sensor. Would a failed timing guide do this ??? NEED HELP ASAP !! WANT TO KNOW WHAT HAPPENED TO THIS ENGINE BEFORE INSTALLING NEW ENGINE .
THANKS !!
ALSO THE CAR , WHEN YOU TRY TO START IT , TURN KEY AND NOTHING !!
Old 09-01-2014, 09:45 AM
Do you get lights on the cluster/dash when you turn the key? If not, you have a battery/voltage issue. Even a low battery would light up your cluster when the key is turned on. There are main fuses above and forward from the battery you might look at. If you are getting lights and no crank, I would still suspect a weak battery. I would take it to have it load tested. Most auto parts stores do this for free. If it's proven good and you have lights but no crank, that's often a sign the key and ews have lost sync. Do you have another key to try? There are other things but need to know if you are getting any lights at all.
Old 09-02-2014, 06:13 AM
battery volts at 12.8 ,but had cables on it from my truck charging it , re-scan and came up with code 148 immobilizer.
Ews system !! Does anyone know how to sync them up , original key and module .
This car was running and just shut off and would not re-start , car sat for 6 months . So i charge the battery and scanned
the car ,came up code 148 immobilizer . Do i need a new ews system with key and ecm or can i re-set this system ??
you can call me also 571.991.5261 tommy
Old 12-19-2014, 03:04 AM
Buick Buick is offline
Mein Auto: 1997 740iL
Hi Tommy
How did you go about solving the no start by the key issue above after the engine change?
I have a similar case on my hands on 740, 97 model that has an engine from a 740, 98 model.
Is there a key code that has to be reprogrammed on the immobilizer system or what?
Ari
