Old 09-02-2014, 11:14 AM
Shua22 Shua22 is offline
Mein Auto: 2013 535i XDrive MSport
Robotic works for me... but good tip on the "navigate to..." - I'm going to try that later.
Shua22's 535i XDrive MSport
2008 535xi
2011 535xi
2013 535xi MSport
Old 09-02-2014, 11:54 AM
jfedor jfedor is offline
Mein Auto: 535I
the navigate to... has always worked pretty well for me.
Another question, probably should be a new topic but has anyone been able to search for POIs via voice? All I can get the car to do is get to the POI screen.
____________________________________________
2013 535i 6MT
Prior: 2001 325i 5MT - RIP thanks to hurricane Sandy
Old 09-02-2014, 12:51 PM
bmw325 bmw325 is online now
Mein Auto: 528i
Yes I have.
However, it won't work if the car doesn't have a connection to BMW online (or BMW online is down as happened recently apparently). An easy way to check might be to see if the online weather widget is working.
Old 09-02-2014, 05:08 PM
Mein Auto: 535I
I never had the weather widget for some reason, not sure if its a 2013 vs 2014 issue.
2013 535i 6MT
Old 09-02-2014, 05:39 PM
hufington's Avatar
hufington hufington is offline
HUFINGTON
Mein Auto: '16 BMW 550xi F10
Originally Posted by K-A View Post
How do you send it via Maps?
The easiest way is using Chrome web browser (after you sign in) or using send to car app from Google Play Store.
16 BMW F10 550xi - 4.4 L 330 kW (445 hp) Fully Loaded w/ ZLL,ZCW,ZDH,ZLP,XDB,ZEC,ZLS,2TB,0456,S6UKA,6NS[/COLOR]
13 BMW F10 535i RWD - 3.0 L 221 kW
07 BMW E64 630i - 3.0 L 200 kW
03 BMW E65 745i - 4.4 L V8, 242 kW
98 BMW E39 535i - 3.5 L 183 kW
95 BMW E34 540i - 4.0 L V8 210 kW
89 BMW E30 M3 147 kW
17 MB C217 S550 4MATIC Coupe
15 MB W222 S550 4MATIC
10 Infiniti G37x Sedan
09 Mercedes C 350
08 Infiniti G35x Sedan
04 Mercedes CLK 350
01 Mercedes C 230
Old 09-02-2014, 05:42 PM
hufington's Avatar
HUFINGTON
Originally Posted by bmw325 View Post
Are you saying the city and state? If not, it will come up with some weird random thing.
Just press the voice button, wait for the tone, and say something like "Navigate to 500 Broadway, New York, New York" . Works 99% of the time on the first try for me. Speak in a normal tone at a normal pace. Of all the voice recogntion systems I've tried, the BMW is proabbly the best. I never bother using the controller for address entry anymore.
I am saying Navigation -> Navigate to -> (address with city and state) and still ending up in Idaho or some weird location. It worked once when I tried a very simple address in Manhattan, but the more complicated the address is the less correct it is.
09 Mercedes C 350
04 Mercedes CLK 350
01 Mercedes C 230
Old 09-02-2014, 06:09 PM
Mein Auto: 528i
Enter street address via voice command
Hmm- can you give me an example of a complicated address?
Also, you don't need to say navigation first. You could be on the radio screen and still say "navigate to some address". Same thing goes with most other voice commands - the NBT idrive is designed to be modeless
Old 09-02-2014, 06:25 PM
hufington's Avatar
HUFINGTON
Off the top of my head:
770 New Jersey 15, Lake Hopatcong, NJ 07849
09 Mercedes C 350
04 Mercedes CLK 350
01 Mercedes C 230
Old 09-02-2014, 06:29 PM
Mein Auto: 528i
Ah that does look pretty tricky. I'll try it next time in my car just to see.
Old 09-02-2014, 06:34 PM
DrFlsgood DrFlsgood is offline
Mein Auto: 335XI, X3, 535XI
Voice POI
Have your phone connected, and the BMW app running to allow internet access.
In the navigation menu, select POI, use the voice command to say the name of the business, restaurant, or address. (the BMW app should be connected and running on your phone.)
This seems to get me the address I want with least amount of hassle. You will see several options in the right hand of the screen and you can select from the # associated with that find, by saying the number, the navigation will give you the Phone and address of what you decide. then select or say Navigate to #1 (3,4, or what matches your destination.
Old 09-02-2014, 07:17 PM
Mein Auto: 528i
The internet access used by google voice saerch, bmw online, etc provided by a 3G data connection built into the car; it does not use the data connection on your phone. Now, if you are using BMW apps such as Pandora running on your phone, that of course uses your phones data. Any good luck you've had using voice search with the phone connected is just a coincidence (though I suppose if your phone has a good data connection the odds are better that the car also has a good data connection).
Old 09-03-2014, 01:45 PM
hufington's Avatar
HUFINGTON
Had any luck?
09 Mercedes C 350
04 Mercedes CLK 350
01 Mercedes C 230
Old 09-03-2014, 02:24 PM
Mein Auto: 528i
Had any luck?
Sorry haven't been in the car yet- maybe this weekend
