Old 08-27-2014, 12:41 PM
AL2504 AL2504 is offline
Mein Auto: F11 520d
F11 boot release
I've got an F11 and the main boot release stopped working today. I can open the glass section but the main boot will not open. We're away on holiday at the moment and lifting a double pushchair out of the glass section isn't ideal. Does anyone know if there is an emergency release within the boot which I can use until we get home? I've had a look but haven't so far located anything. Cheers
Old 09-01-2014, 09:39 AM
josh1e josh1e is offline
Mein Auto: BMW F11 520d M Sport
Hiya.
I have a 2011 F11 and having stripped all the back panel to check (after locking myself out of it previously), I can confirm there is no emergency release.
the only way of opening the boot are
  • keyfob
  • button on outside of tailgate
  • button in driver footwell
it's worth mentioning that on mine, the drivers door needs to be unlocked before either of the boot lids will unlock..
hope that helps, enjoy your hols!
Old 09-02-2014, 01:01 AM
Alex75 Alex75 is offline
Mein Auto: 2012 F11 520dT
In my 2012 F11 I found a steal cable with a loop at one end that looks as if it was meant to be pulled to release something. I always assumed it was the emergency trunk release. It is tucked away near the battery. But I cannot imagine how someone could access it with the trunk closed, since you need to open the floor trap and remove a part of the floor storage compartment liner to get to the battery area. I don't think the floor trap opens high enough to reach in through the open window with the trunk closed.
I'll try to get a picture of it tonight.
Old 09-02-2014, 10:28 AM
I can now confirm that my F11 indeed has an emergency trunk release. I can only assume yours has one as well.
I took some pictures to help you find it. The floor compartment opens relatively high and you should be able to get to it through the open trunk lid window.
Open the floor compartment. The storage compartment liner under the floor has one plastic retaining plug. Use a flat screwdriver to lift the center part of the nut until you can grab it with your fingers. Pull the plug out.
Now you should be able to lift the liner to get to the battery compartment.
In there you should be able to find a black plastic cable coming from the trunk locking mechanism. At the end of the cable there is a blue loop.
This is the emergency trunk release. It is a narrow steal cable surrounded by a black plastic guiding tube. I have tested it to confirm. Hold the plastic tubing at the yellow part near the blue loop. Now pull the blue loop away from the yellow part until you hear the trunk lock disengage. I think I needed to pull the loop for about an inch or two.
You can easily route the emergency release outside the storage compartment into the trunk so you can use it through the open window without having to access the battery compartment, that way you can use it when you have stuff in the trunk that would block access to the storage compartment under the floor.
Old 09-02-2014, 02:23 PM
Gilgorm Gilgorm is offline
Mein Auto: 2012 535i X-drive
Just to make sure, have you or kids or anyone else slid the "valet lockout" button in the centre armrest to the lock position?
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i
Old 09-03-2014, 09:13 AM
Mein Auto: F11 520d
Thanks for replies. I did the other night manage to release the boot by lifting the boot floor which gives access to the tailgate lock and it can be release by manually operating the actuator. Next I removed the panel from the rear of tailgate to investigate the switch and putting a jumper across the wires resulted in the lock operating. I then removed the hand/switch part to discover the failure was due to a poor design. The micro switch in the handle is operated by a flat section of plastic that pushes the switch when the handle is pulled, this is achieved by the flat plastic rotating by way of the rubber seal. The rubber had split hence no rotation occurring and therefore contact with the switch not be achieved. As I didn't really wish to have to take it all apart again I set about repairing this and manufactured a piece to hold the rotation part in the correct position . Works perfect now.
Old 09-03-2014, 10:21 AM
Originally Posted by AL2504 View Post
Works perfect now.
Old 07-25-2015, 07:27 AM
Mein Auto: F11 520d
Well it's been almost 1 year and the new saga with the boot release commences - the soft close has stopped working, thought it was unusual getting the boot open warning a couple of times recently Will have to find some time to look at this, at least this time I can still open the boot
Old 05-20-2016, 03:06 AM
gbshahaq gbshahaq is offline
Mein Auto: F11 520d SE
I have a Sept 2010 F11, and the tailgage won't open. Fuses 153,155 and 183 pulled and checked - all ok.
The tailgate window opens, and I had a VERY good search around underneath the boot floor and found no emergency release cable
There is what looks like an actuator motor on the left side of vehicle, with a sheathed thin steel cable coming from it towards the centre of the boot. There is a 2-3 inch of cable exposed, so gave it a tug, but didn't make a difference.
Any other ideas?
Old 05-20-2016, 06:33 AM
Mine was tucked away at the bottom of the battery compartment on the right
Old 07-20-2016, 08:23 AM
MikeT1164 MikeT1164 is offline
Had the same thing. Fitted new boot release switch as detailed above, 21.60 from BMW dealer delivered same day and five minutes to swop over with no tools needed. Absolute result! Thanks Chaps.
Old 07-23-2016, 09:21 AM
maxymos maxymos is offline
Mein Auto: Italia
Hello everyone, I have an F11 of 2011 and the same thing happened to me door locked, only that in my car does not have an emergency cord to unlock , how can I replace the handle ?
Old 07-24-2016, 01:50 PM
Hi the handle just pops off if you get a finger under the edge. There are plastic catches that are part of the handle but does not take much for them to pop off. At worst a screwdriver and a rag to protect the paintwork is all you need.
Old 07-24-2016, 03:26 PM
Mein Auto: Italia
Hello , thanks for the reply , so it is not screwed in from above the handle ? I can force to release it ? thanks is still sorry for my English .
Old 08-09-2016, 12:37 AM
No screws - just held in tight with plastic clips.
Just pry it gently off with something that won't scratch/dent your paintwork.
Old 08-09-2016, 12:41 AM
Mein Auto: Italia
Yes I did it this way I solved it ..... thanks for your reply
