Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 12-22-2001, 06:31 PM
Mystikal Mystikal is offline
Kickin' it old school
Mein Auto: E30 325is
Help! E46 Front signal removal
Is there a trick to getting the signal assembly out or what? The manual is incredibly vague, but I'm pretty sure I found the right "tab". I'm putting pressure sideways relative to the front of the car, and I can see the light popping out slightly. But just getting to that stage requires quite a bit of pressure. Is that normal or is there some other way to get it out?
I know those with clears should know what I'm talking about. All I'm doing is replacing a burnt out bulb, but it looks like it's the same procedure.
Old 12-22-2001, 06:32 PM
LilEccentricJ's Avatar
LilEccentricJ LilEccentricJ is offline
pimpee
Send a message via AIM to LilEccentricJ
Mein Auto: 2004 GMC Duramax Diesel
Check DIY at www.bmw330ci.com
New Sig SOON!!! Just need to find time to make an 11 MB flashing sig file for my new truck
Does anyone rememeber my BMW?
Old 12-22-2001, 07:03 PM
Thanks, that DIY is indeed very informative. But still, that thing just isn't coming out. I'm pulling the tab with the screwdriver very hard while simultaneously pulling on the lens itself, which pops out about 10mm when the tab is being pulled. It's just not moving.
Has anyone else had this sort of difficulty?
Old 12-22-2001, 07:10 PM
pimpee
Exclamation
Pulling? You need to push down on the tab and try to (using the driverside as an example) pry (with your finger/fingernail) the bottom inside front corner of the lens toward the corner of the car while then pushing the tab you depressed with the scewdriver toward the front of the car. BUT, nothing should need "forcing"!
Did I explain that right? I understand it but NE1 else?
Old 12-22-2001, 07:13 PM
pimpee
Lightbulb
Look at the DIY file page again. The part of the lens that is almost touching the words "change out" at the top of the page is what I am saying to pull on after you have depressed the catch tab with the screwdriver. Also make sure you are depressing the right tab through the right hole in the fender. (you can substitute the word "right" in this post with "correct")
Old 12-22-2001, 07:25 PM
Okay, what I did all matches up except for the "push down" on the tab. I'm moving it laterally, as in towards the side of the car. The lens moves out when I do that, so I figured it was correct.
Do you think that's what I did wrong?
Old 12-22-2001, 07:28 PM
pimpee
Not sure exactly but make sure when you put it back in that you look carefully to line up the finger and the catch tab into their little spots and that it "clicks" in. Use your whole palm to push so you don't crack anything and DON'T force anything. Lemme know how it goes.
Old 12-22-2001, 07:51 PM
Not a chance.
I'm now almost sure that I must be playing with the wrong tab, because nothing is working.
I'll just drop by BMW tomorrow and ask them to show me how. I can't believe I have to resort to that.
Old 12-22-2001, 07:54 PM
pimpee
Unhappy
Sorry we couldn't get this thing fixed tonight but better safe than sorry, right?!.
Old 12-22-2001, 08:03 PM
Yeah I know, the last thing I wanted to do was snap one of those little tabs. That's why I'm scared to keep trying.
Thanks a lot for all of the help and info JB, I appreciate it!
Old 12-22-2001, 08:07 PM
ashecnc's Avatar
ashecnc ashecnc is offline
Formerly CCs328Ci
Mein Auto: 2013 328i convertible
Talking
Hey, bring it over here and I'll do it for you...no charge
Old 12-22-2001, 08:11 PM
LOL, yeah, just the small amount of gas that I'll need to reach down there
Old 12-23-2001, 04:27 AM
Keith(UK) Keith(UK) is offline
Mein Auto:
The tab is plistic and MUCH deeper than you expect-you will have difficulty seeing it! Good luck!
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 01:44 AM
My E36 v. E46 thoughts (very long) JST 1M & M2 49 12-18-2006 12:45 PM
E46 M front strut brace on 330i PG 3 Series & 4 Series 4 02-19-2003 02:50 PM
Front tire sizes for E46 Ashe too 3 Series & 4 Series 3 12-31-2002 06:52 AM
Right front turn signal problem Big Al 330i General BMW Questions 10 10-11-2002 11:20 PM
