Lets 3.46 differential my '01 M-Z3 coupe, part 1 - Bimmerfest - BMW Forums
Old 04-14-2002, 09:34 PM
Ron Stygar's Avatar
19,585 Miles
The '99/'00 M-Z3 coupe with the S52 engine has a 3.23:1 differential.
The '01/'02 M-Z3 coupe with the S54 engine has a 3.15:1 differential.
Based on the 7600 rev limit on the S54 engine, the 3.15 differential is not a good match for the car in my opinion. Have no idea why BMW really did this.
Looking to change this, I first focused on the 3.38:1 based on the numbers, and settled on the 3.46:1 used in the Z3-3.0's with automatic.
Back then, I had no idea if this unit would fit or work with the M. At the time we knew that the rear covers were different. We also knew that the output flanges were different, but based on the parts data the M ones would swap right in. The driveshafts are different lengths too.
But based on both differentials using the same input flange, we assumed it would work.
Al Corey (took the chance) purchased one to see. The differential retails for $2200.00 with a $100.00 core charge. So, if you want, you can keep your stock differential for $100.00.
He installed it and it fit fine. When we took it out for a test drive there was no speedometer reading. Turns out the speed signal generator (spider) is different, diameter wise between the two differentials.
Since BMW no longer sells internal differential parts, there was no way to check this since the internal parts no longer show up on the parts CD. They show up if you know the part number, but that's another story.
Al modified his speed signal sensor so that it would go in more. It worked.
Randy Forbes swapped out the speed signal generator (spider) with the one from his M differential and it worked too.
I had my machinist modify a speed sensor based on what Al found out. He also made me a plate to accommodate the shortened sensor.
After three unsuccessful tries, the fourth differential I ordered showed up undamaged.
Time for me to finally 3.46 my '01 M coupe.
Last time I swapped out a differential was over forty years ago in my '61 3 speed Chrysler. Used to swap back and forth a 4.11 with the stock 3.23 as needed. Looking back, I have no idea how I did this.
I remember slam hammering the axles out and removing the rear cover.
Five years earlier my first car was a 40 Ford Deluxe coupe.
Pontiac V8 with a '39 Lasalle tranny and Ford rear end. No idea how I did this either. At fourteen, I never finished the car. The guy I sold it to did though. My older brother, being into cars, got me into cars.
Part 2 to come.
Preview: I got the stock differential out.
Old 04-15-2002, 03:49 PM
SilvyinLA SilvyinLA is offline
Mein Auto: 1999 M Roadster
Going to ask a stupid question...
Will this make the car easier to drive when in 5th gear?
My brother has a 95 M3 and in 5th gear on the freeway it revs sort of high. I thought a 6th gear would make the car easier to live with on long drives.
Is this the same sort of thing what you are doing will do? Lower the rpms when in 5th gear....
Sorry for such a simplistic question.
By the way the bottom of your car is too clean...you need to drive it more.
99 M roadster
White/Black Orange
2002 Mini CooperS -on order
Old 04-15-2002, 05:57 PM
Ron Stygar's Avatar
19,585 Miles
RPM's
The 3.46 is roughly a 10% change which will increase the RPM's for any given speed. 70 MPH in fifth gear is 3250 RPM. Based on the S54 engines 7600 redline the 3.46 is a better match for the car.
With a six speed, sixth gear is an overdrive (.83) so it would make the 3.46 differential look like a 2.87 one.
Old 04-16-2002, 05:55 AM
blackdawg blackdawg is offline
Mein Auto: 325
ron, you're a badass and stubborn, too!
lesser men would have sensed fate against them after the first 3 damaged differentials!
please keep updates coming along.
i'll bet the car just flatout rips with the new rear-end.
cheers,
coky nguyen
Old 04-16-2002, 09:28 AM
Steve Borsse Steve Borsse is offline
Mein Auto: 2001 BMW M///Roadster
Thanks Ron, looking forward to the remainder of the installation. Thanks for pointing out to me "bimmerfest." :thumb:
Steve Borsse
Old 04-16-2002, 05:33 PM
Shawn Fogg Shawn Fogg is offline
Mein Auto: Z3
Ron,
Glad to hear you finally got a diff intact! Took them enough tries. I've been checking part numbers for my fathers 330ci... he is thinking about a diff upgrade for it.
Shawn
Old 04-19-2002, 01:50 PM
Christian's Avatar
Christian Christian is offline
Project No Budget 1.9
Mein Auto: 1997 Z3 1.9
Question What's the status on th rear diff install?
Ron, just curious as to whether you've finished your rear differential intall or not. I'm very interested to hear the end result.
Old 04-19-2002, 06:07 PM
Ron Stygar's Avatar
19,585 Miles
Smile Install finished
Finished the install Monday night. Have around 200 miles on it since then. No droning, vibrations or leaks. Still breaking it in.
From BMW:
I'm not sure what the above statement means. I assume 2/3 of maximum speed in 5th gear, which is not a problem over here.
Mileage appears better (based on the OBC) with the new differential cruising at 71 MPH. Also measuring differential temperatures etc. Will try to post part two of the how to Sunday night. Have a lot of pics to edit etc. Going to Limerock tomorrow so it won't happen then.
We have planned testing of Al's car with Shawn Fogg sometime soon.
As mentioned, the 3.46 is a nice match for the car.
Preview:
Coming out. Since the differential weighs 83 pounds, having a nice jack makes this much easier to do.
Old 04-19-2002, 07:00 PM
Christian's Avatar
Have fun at Lime Rock!
Old 05-23-2002, 11:50 PM
Ron Stygar's Avatar
19,585 Miles
Speed sensor apart
As mentioned, we modified the stock M sensor to go in more so that the smaller diameter speed spider in the 3.46 differential would mate with it.
The covers and sensors are different between the M and the 3.46 differential. If you were to keep the 3.46 cover using the 3.46 sensor everything would work fine. If you want to use the M cover with the 3.46 differential you have to change out the speed spider or modify the sensor.
I modified the sensor and it appeared to work fine initially. The sensor Al modified when he did his car is still working fine.
Depending on the drive time the speedometer signal becomes intermittent. This has been driving me nuts for the last couple of weeks. Appears to be temperature related. Thought it might be wiring based on me not disconnecting the plug when letting the differential down. Thought it also may be related to the many mods I've done using the speed signal.
Have a 3.46 sensor coming tomorrow so that I can compare things dimension wise. I have both the M and 3.46 covers.
If you place a scope across the speed sensor you will see a 5 volt square wave referenced to ground when working. When its not working the square wave goes away and you see a line on the scope at ground.
Wasn't sure how the sensor worked. Took one apart tonight to see.
In one prong of the sensor is a switch. In the other a magnet.
The magnet closes the switch (ground). When the magnet is interrupted by the speed spider blade, the blade shunts the magnetic field and the switch opens (5 volts).
I have a thermocouple attached to the differential case to measure temperature, which goes to a meter in the passenger seat.
I also have a lead paralled with the sensor going to a scope in the passenger seat footwell.
Knowing how the sensor works, I can now place an ohmeter across the sensor leads when it fails and hopefully figure this out.
Come this Winter, I will be installing the M spider in the 3.46 differential.
Old 05-24-2002, 07:57 AM
Gus Gus is offline
Mein Auto: 99 Euro M Coupe
Question Do 99/00 Euro cars have different ratios?
Ron,
I am going to go for a drive later to day and check out the RPM/Speed ratio, as I believe that my car revs higher at the speeds posted. I am not 100% sure about this, but I will "have to" to out now for a drive! Will post the results. Give the incredible traffic here, its bound to be a challenge to do so...
Gus
Old 05-24-2002, 09:30 AM
Hay Gus!
If you'd like me to check my RPM at a certain indicated speed, let me know what numbers you want checked. Just not anything over 5k in fifth!!! I have the 3.15 rear end in my 01 M///Roadster.
Have a great weekend, looking forward to seeing you a couple weeks! We'll see what we can do about adjusting your hood. I've been practicing "mi Espanol cada dia": "Tiene una cervezas muy fria, tenemos sed!!!"
Steve Borsse
Old 05-24-2002, 12:25 PM
Gus Gus is offline
Hola Steve
Keep practicing that Spanish! :thumb:
I am the one who is going to verify for Ron the RPM to speed ration on my car and see if its a 3.15 or what that I have in there.
I promise not to go over 6K rpms in 5th Maybe not?
Z ya soon!
Gus
Old 05-24-2002, 05:34 PM
Ron Stygar's Avatar
19,585 Miles
Speed sensor problem solved
Reference the picture below.
The Z3-3.0 speed sensor arrived today. Compared it dimensionally to the M-Z3 one.
From taking the M one apart last night, I now know how they work. Based on this I checked the trigger point on the
Z3-3.0 one. Although the 3.0 one is shorter, its trigger point is further out towards the tip of the prong than the M one. Bingo.
Looking at the pic the stock M one trigger point is .074" away from the end of the spider blade tip. By modifying the sensor to go in around .1" the tip just goes over the trigger point. On Al's car this has not been a problem, yet. On my car it works fine initially and stops working after the differential heats up.
On the 3.0 unmodified one the blade tip is past the trigger point by .328". More then enough margin.
Keep in mind that why this is necessary is that the speed spiders are a different diameter between the 3.46-3.0 and 3.15/3.23 M differentials, The 3.0 cover (where the sensor mounts) is thinner than the M one.
So now, instead of swapping spiders or modifying a sensor, you just have to replace the M sensor with the 3.0 one.
Finally!
Old 06-09-2002, 08:37 PM
bmwRobert bmwRobert is offline
Mein Auto: 01 Mcoupe or......
THanks Ron...the diff SINGS!
We did it. Last week we installed a 3.46 diff (from a 2000 Z3 auto)in a 2001 M coupe. Thanks to Ron Stygar who did the R&D and showed us the way. The car drives as it was ment do drive. What was BMW thinking putting a 3.15 in that car.
We got the diff from Pasific BMW for $1750. Install is a straight bolt on. We even used the Mcoupe diff cover so everything looks stock. We did have to swap out the Mcoupe speed sensor with a 2000 Z3 3.0 speed sensor (as Ron recommended) to make everything work correctly.
This weekend the car was driven 1000 miles (600 miles per BMW recs) as part of the break in period for the diff.
Now it just ROCKS!
THANKS Ron you are the GURU! http://community.webshots.com/photo/...32881676bvwevy
RPS
01 Mcoupe
00 r1200c
97 M3/4 sc
74 02tii
73 02tii
71 2800cs
Old 06-10-2002, 09:25 AM
kaiwang kaiwang is offline
Mein Auto: 01 M Coupe
1/4 mile times with new diff
With the new Diff, it would be interesting to see 0-60 and 1/4 mile times.!
Old 06-10-2002, 07:58 PM
Randy Forbes's Avatar
Investigative Tinkerer
I hope to get my car out to the strip for some timed runs sometime this summer.
I got out late last fall and was only able to make two passes on a very busy "test-n-tune" night.
The car only had around 3000 miles on it, and I've since learned that it isn't a "fast track" as far as times go.
My best that night was a 13.8 at maybe 104mph with the 3.15:1.
The plan is to make it over to Norwalk (?) where they have some kind of high traction surface. That and a 3.73:1 should make a world of difference. Plus mounting the Hoosiers on the rear only.
Randy Forbes
2001///M Rdstr Steel Gray
Old 07-23-2002, 01:21 PM
caylan caylan is offline
Mein Auto: 2000 M Coupe
curious is this 3.46 a torsen type?
Limited Slip Diff?
Old 07-23-2002, 01:26 PM
Ron Stygar's Avatar
19,585 Miles
Re: curious is this 3.46 a torsen type?
Originally posted by caylan
Limited Slip Diff?
Torsen style. Torsen style only used in the non M-Z3's based on my research
Old 07-23-2002, 02:47 PM
phrider's Avatar
phrider phrider is offline
Equine 1/4 miler ancestor
Mein Auto: 2001 M Roadster, 1998 M3
Re: Re: curious is this 3.46 a torsen type?
Ron, to avoid confusion for all of us that are contemplating this now or in the future, what is the full part number on the Torsen 3.46 differential?
Thanks for your R&D efforts.
Old 07-23-2002, 07:31 PM
Ron Stygar's Avatar
19,585 Miles
Re: Re: Re: curious is this 3.46 a torsen type?
The part number shown is for the remanufactured differential which is basically like a new one, based on the four I got to look at.
The new part number is the remanufactured number minus 1.
Don't think that the new part number is available through the parts system.
This minus one thing works on transmissions too, and I assume other things.
Knowing this, if you had a part number list of the new differentials used in Z3's that were Torsen style, you could add one and see if they were used only in the non M-Z3's or whatever.
I went with the 3.0 from BMW because it was a Torsen style and it was like new. Torsen folks said that it would have no problem handling the M's power. It appears, so far, to work very well with the M DSC.
The differential retails for $2200.00. For an extra $100.00 you get to keep your stock one. Good deal in my opinion.
No history on this when this was first done, so a back up was nice. Sell the car, switch back the stock one and easily sell the 3.46.
Paul McLaughlin (1-800-883-7278) at South Motors BMW in FL will discount 25% from true suggested retail plus shipping. He's sold eight of them so far and has the packing down, so that you will only have to order one of them.
45 ring teeth divided by 13 pinon teeth = 3.4615
Quiz: Does the driveshaft turning around once make the wheels go around 3.46 times, or does the driveshaft going around 3.46 times make the wheels go around once?
Old 07-23-2002, 07:36 PM
Christian's Avatar
Driveshaft rotates every 3.xx times for each time the rear wheels spin. Correct?
Old 07-24-2002, 02:13 PM
Ron Stygar's Avatar
19,585 Miles
Correct. Email me your address and I'll send you a prize.
Old 07-29-2002, 06:11 AM
M Power M Power is offline
Send a message via AIM to M Power
Mein Auto: 2008 X5 4.8i
I've upgraded my differential from 3.15 to 3.46 about a week ago. This thread has been very helpful in making my decision. The total cost of upgrade was about $2500 from a local BMW dealer that includes BMW warranty as well.
As for performance, the car noticeably pulls faster in each gear as it was mentioned already. Definitely a worthwhile upgrade, IMO.
2011 X3 35i
2008 X5 4.8i
2003 330xi -sold-
2001 X5 4.4i -sold-
2001 M5 -sold-
2001 M Roadster (SCed, Highly modified) -sold-
2000 M Roadster -sold-
1995 325is -sold-
Old 07-29-2002, 12:13 PM
Tommy V Tommy V is offline
Send a message via Yahoo to Tommy V
Mein Auto: 2002 M Coupe
Thanks Ron
Ron,
Very appreciative of your post here as well. It was instrumental in my choice to change diffy"s.
Very happy with the change! Car pulls hard through all gears like it should have. Also notice that bogging in first up to 2K RPM is mostly gone as well.
Tommy V
02 Steel Grey MCoupe
Ground Control Suspension: 450F/600R Eibach - Koni SA
Ground Control Rear Mounts
Supersprint Dual DTM
UUC Short Shift & Tranny Mount
UUC Big Boy Clutch Stop/Rob Knob III
HMS Harness Bar/Schroth 4pt
3.46 Differential - Great!
Valentine 1 Hardwired
SS CL Stut Bar
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 06:38 PM
3.46 installed JonM E36/7 Z3 (1996-2002) 15 12-11-2003 10:54 AM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
Trivia... 99 Z3 Coupe Graphit Interior Trim JonM E36/7 Z3 (1996-2002) 18 09-19-2002 01:23 PM
