Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 09-04-2016, 03:21 PM
HELLR0T HELLR0T is offline
It means bright red
Mein Auto: 96 E36, 14 F30
M stripe grille options. What do you recommend?
I see a ton of different options online for the m stripe grille. Can anyone suggest a product they have used and like? ThanksClick image for larger version
Old 09-04-2016, 09:55 PM
vegasgolds vegasgolds is offline
Mein Auto: 2016 BMW M235i
use this link... https://www.ecstuning.com/BMW-F22-M2...r/Body/Grille/
2016 BMW M235i..... very happy with this purchase
Old 01-16-2017, 02:10 PM
USA-RET's Avatar
USA-RET USA-RET is offline
Mein Auto: C7 Corvette Mini CooperF5
Originally Posted by HELLR0T View Post
I see a ton of different options online for the m stripe grille. Can anyone suggest a product they have used and like? ThanksAttachment 575095
Went on Amazon and ordered 1/4 inch pinstripe.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1/4 inch comes in this purple, light blue and red. The light blue looks aqua in the pix but it is really a light blue
10 minute job w/ a razor blade and small screw driver ( screwdriver blade to start the stripe in the upper angle of the grille vertical tooth and again to finish at the bottom).
Holds up well, and looks clean, if you decide you don't like it later on, peel the stripe off.
Name:	2004-01-13 04.15.05.jpg
ID:	587074   Click image for larger version
Name:	2004-01-14 00.08.39.jpg
Old 01-16-2017, 04:43 PM
sttkailua sttkailua is offline
Mein Auto: M240i
Ret-USA,
yes, looks good!
I was going to buy 3 rolls of electrical tape to match the M colors.
You can then stripe the fins you want, then have the rest of the rolls to use
around the house for other projects.
stt
Old 01-17-2017, 07:07 AM
USA-RET's Avatar
Originally Posted by sttkailua View Post
Ret-USA,
yes, looks good!
stt
I was looking at that option also. I hit a couple of hardware stores and saw some 3M tapes. I could not find a light blue color. The red was perfect and purple was very close, but no light blue.
Also wasn't sure how that tape would look wrapped around each grille tooth (as the tape would "pucker' at each bend. I also though about cutting the tape to 1/4 " on a pane of glass w/ a straight edge to just do the leading edge.
Finally decided to just buy the pre-cut 1/4 inch pinstripe. More expensive, but has the right texture, color and shine when done. Plenty of left over for a "do over" should I need to.
I looked at the snap on stuff sold on Alibabba, but thought adding a plastic sleeve would not look right. Other options considered were pre-painted replacement grilles (prices ranging from $75-$110 a set). They also sold the M2 style double tooth, but after seeing the videos to install, came back to the pre-cut pinstripe.
I have a local pinstripe/graphic/window-tinter that likely would have done it for less than $20 (and probably would have covered the entire grille tooth), but thought I'd go the DIY route first.
Old 02-02-2017, 11:13 AM
RW Carbon's Avatar
RW Carbon RW Carbon is offline
Mein Auto:
It's fairly common for customers to purchase the gloss black grilles and pinstripe them themselves. If it looks bad or you don't like it, you still have gloss black grilles!
"One Goal, One Focus - Carbon Fiber"
Find BMW Carbon Fiber Parts | Web: www.rwcarbon.com
email: greg@rwcarbon.com | Facebook | Blog | Instagram
sales/customer service: 714.328.4406
Old 02-03-2017, 06:28 AM
Zheeeem Zheeeem is offline
Mein Auto: 2014 M235i
As if the M235i/M240i was somehow deficient in badging.
Old 02-24-2017, 10:09 AM
USA-RET's Avatar
My M240i came with two badges (that one can readily see). One on the trunk and one small one on the steering wheel.
Yes, wheels have tiny ones too....as well as the engine cover. With hood closed you can't see it and unless your on your knees not likely to pick up the ones on the wheels either. So I count two.
Not sure how many came on the M235i
Old 02-28-2017, 08:49 AM
MSgtMel's Avatar
MSgtMel MSgtMel is offline
Familienwappen
Mein Auto: '16 M235xi, '16 X3 35xi
Unlike you guys, I'm a little behind as mine is a 2016 M235xi. Got it 30 Dec.
FYI
There are a total of 11 M badges from the factory on the car:
Engine cover [1]
Steering Wheel [1]
Instrument cluster when first turned on [1]
Tail board (trunk lid) [1]
Door sills [2]
Wheels [4]
these are all in color plus a monochrome badge on the dead pedal cover = 11.
P.S. The worthless ambient lights are in the top of the cove for the door opening lever and at full brightness need a reflector above the lever to barely be able to be seen!
Wir koennen alles. Ausser Hochdeutsch
Old 02-28-2017, 09:12 AM
mecodoug's Avatar
mecodoug mecodoug is offline
Mein Auto: '17 M240i
Mine also has one on the gear shift knob (manual transmission).
2017 M240i 9/6/16 ED Mineral Grey/Oyster/MT/ZCW/ZDA/Nav/H-K/CP/black grille/aluminum pedals/CF mirror caps
2011 335d 6/28/10 ED Tasman Green/Saddle, ZPP, ZSP, ZCW, Nav, H-K audio, paddles, CA
2012 Ford F-150 XLT 4x4 V6 twin turbo
Sold: 2006 330i Silver/Black MT, ZPP, ZSP, ZCW
Old 02-28-2017, 09:26 AM
USA-RET's Avatar
FYI
Engine cover [1]
Steering Wheel [1]
Door sills [2]
Wheels [4]
Forgot about the door sills, when they are closed, I don't see them. Never noticed the dash cluster logo either (but yes it's there). Outwardly, the only thing that really identifies the car as a M240i is the trunk lid IMO.
Didn't the M235i have front fender M logos too?
Old 03-06-2017, 10:36 PM
mine doesn't
Old 03-07-2017, 06:19 AM
USA-RET's Avatar
Wonder if they were only on the Euro models? The link is a 2014 M235i review and that example has the side fender logos (just above and behind the front wheels).
http://www.canadianautoreview.ca/rev...BMW-M235i.html
Old 03-07-2017, 06:39 AM
MSgtMel's Avatar
Familienwappen
Mine doesn't as well. Though did add 4 more by installing the M logo valve stem caps on the wheels. Ha.
Old 03-07-2017, 09:32 AM
mdputnam mdputnam is offline
Mein Auto: 135i & 235i Convertibles
In the US, the 2014 model year was the only one that had the M logos
on the fenders.
Old 03-08-2017, 03:48 PM
MSgtMel's Avatar
Familienwappen
Any way back on track - has anyone found a tape/wrap that properly does a match/close match for the "M" colors for the stripes?
No I don't mean any kind of lavender/purple for the near navy blue middle stripe either.
Old 03-08-2017, 04:00 PM
This $0.99 stripe kit probably won't help.
Old 03-08-2017, 04:22 PM
MSgtMel's Avatar
Familienwappen
Hmm, looks good on the monitor, and for a couple bucks shipped, no terrible loss if it doesn't. THX
