Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 02-07-2017, 12:52 AM
notlkk notlkk is offline
Mein Auto: 228i
Those Seat Memory Buttons on my 228i...OMG
Is it just me or those buttons look like they're from 1980's? I mean WTF? Can't they make them a little modern?
Also, I have to press and hold the button until my seat stops moving to get to the memorized position. That's another WTF. Why can't I just press it once without holding it? I think that's the way most of the cars work (at least Lexus, Infiniti, Hyundai).
Old 02-07-2017, 03:54 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Because if you accidentally press a button which is set for someone much shorter than you, you can find yourself rammed into the steering wheel. The lawyers would rather you hold the button to get that to happen, rather than have the car ram you into the wheel all by itself.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 02-07-2017, 08:46 AM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
Unless they have changed something, if you press the button before you get in the car you do not have to hold it. This was very convenient in my 1999 528 because my wife is very short and if I got in before adjusting the seat I would be scrunched up against the steering wheel.
Old 02-08-2017, 10:58 AM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
Ignition off: press and release.
Ignition on, seat belt on: press and hold.
RTFM p 55*
* Like most BMW owner manual explanations, this one is somewhat opaque, but I think it is pretty clear that press-and-release works when you're not yet in the driver's seat, and maybe when you are seated but haven't yet turned on the ignition or started to put on your seat belt.
