X6 50i E71 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X6 F16 (2015 - Current)
The all new 2015 BMW X6 is the second generation luxury cross over. BMW referes to the X6 as a Sports Activity Coupe (SAC) as it combines the attributes of an SUV (high ground clearance, xDrive and all-weather ability) with the stance, styling and roof line shape of a coupe. The F16 BMW X6 is build side by side with the F15 X5 at BMW's BMW's Spartanburg, SC plant. Read all about the second generation BMW X6 here!
Old 11-22-2016, 05:14 AM
Px6 Px6 is offline
Mein Auto: X6
X6 50i E71
New to this but read , a few postings online decided to give a shot changes all coolant hoses and truck still smokes by turbos ,and from what I can see I don't see any wet spots that it could be coming from , smokes bad and burns eyes thru vents took to BMW Westmont in ll they gave me the par num 17-12-7-576-363 change it to a metel one as it was leaking going to take another look when I get off just don't see paying a dealer 2k for something simple any suggestions? 2009
Old 12-07-2016, 08:53 AM
HPIA4v2 HPIA4v2 is online now
Mein Auto: E60, E71, E92
This forum is for newer X6 though.
But in any rate, you need to see which one is leaking, if the composite part is not crack then you can try putting another worm-drive clamp on it. I did and it stop the leaking.
Also never top of coolant at max or more, just in between min-max, this alleviate the excess pressure but the car still have adequate coolant to be effective
coolant, leak, x6
