Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 02-03-2017, 11:58 AM
mike@x-ph.com mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
Active Autowerke A8 M3/M4 Tune - NEW MAP - Dyno Comparison vs GTS
Active Autowerke have updated their 93 octane map. This new map adds more boost in the midrange and tapers down boost on high RPM.
You now get more power, smoother power delivery and most importantly this map will eliminate the need to gap your spark plugs.
Now for the dyno results
Low run - Stock tune, Active Autowerke midpipe and RK Tunes intake
middle run - Stock GTS
high run - A8 new map with Active Autowerke midpipe and RK tunes intake
Order Link
https://www.x-ph.com/active-autowerk...f8x-m3-m4-s55/
