I've been trying to tackle the issue with AC in my 2003 540i.
I've looked at numerous threads and videos about diagnosing my issue.
Here's what's happening:
Here's what I've done so far:
What other issues can be wrong with the AC system? Does a clogged/stuck compressor prevent the car from turning the AUX fan on?
- The AC function appears to activate: I notice there's a bit more airflow when AC button is activated.
- AUX fan does not turn on regardless of car's temp or AC is on or off.
- AC clutch does not activate when AC button is pressed.
- External temp sensor was replaced and shows proper outside temp.
- AUX fan is not seized, can be rotated easily
- Tested AC clutch with direct 12V - clutch activates (can hear it click).
- Tested the lead to AC clutch but is only at 5V regardless of AC being on or off
- Tested (was good) and swapped out lower radiator temp sensor (AKA AUX fan switch) - AUX fan still does not turn on.
- Checked leads and plug to AUX fan, it gets constant 12V at plug but does not seem to activate fan; third wire has 5V going to it (I assume this wire sends the signal to the fan's "CPU" to turn it on).
- Checked AC charge and recharged it to 40psi.
- Checked blower fuses 75 and 76. Checked all AC related fuses in glove box (9, 20, 7, 20, 22, 23)
