My understanding from the manual and from the dealer is that different key fobs can be set with different profiles that are activated when you unlock the car. My wife and I have different fobs and different profiles that were set with each fob. But when you unlock and start the car it always stays with the last selected profile. If I want my settings I need to manually select my profile and then hit the memory 2 button on the door.
The other way it works is to just set my wife's setting to m1 and mine to m2. Then if she last drove the car I need to open the door, push m2, hold it until all adjustments are finished, then sit down. Otherwise my knees get jammed against the steering wheel.
The dealer said it wasn't working properly because my battery was low. He changed the battery, but no difference. I don't know if I am missing something or it is just not working right?
