OK guys, so i sorted out the check engine light! i got home from school and the next day when i was on m y way to work the weirdest thing started to happen, i would press the accelerator but there would be no revs, then all of a sudden they would shoot up to 3 or 4 thousand, drop down to 500 and the car would die. obviosuly i was freaking out. anyway after having my car towed to my mechanic, he tested the fuel pressure and said that it was fine, we thought it could be either a fuel filter or fuel pump. anyway the car was idling and he was fooling around with some cables, pushed in a plug and everything was fine! what had happened was the plug that operates soemthing that regulates the air in the engine had come loose over time and it had just gotten to a point! now the car drives as if it was brand new and i am SO HAPPY!! (see attached pics) also my mechanic reset my check engine light so all is good.
also, i am in the process of painting my body strips/bumpers and when i was taking them off, i noticed some of the clips holding them in place were a little loose, anyway if anyone knows where i can get a new set thatd be cool, havent checked the dealer yet but i will, also see attached pics!
