Surprised someone has not already picked up the torch and started a class action suit.
It seems they fail unusually early and at a very high rate of failure on the earlier cars - mine failed not that long ago at 20k miles (but 6 years old). Since the car has no temp gauge, you just get a light on the dash to tell you it is overheating and a warning on idrive, by the time you read the warning, it changes from yellow to red (literally less than 10 seconds between yellow and red) then tells you to pull over and reduces engine power to about 1% - it actually happens so quick it is dangerous and should give you a little more warning.
What's needed here is an FDriller special: How exactly are these pumps failing?
I've heard o'motor winding failure. May or may not! Who got good data? If, should be possible to detect breakdown and predict total fail a la 2001, that Space Odyssey, from reflected energy blips along the winding where impedance markedly changes.
A test run's needed and you're just the guy to do it! Recommend: Round trip to Seligman, AZ, with data recorder. Yo! When you arrive, chow's waiting for you here - their motto: "You kill it; we grill it"
The pumps on the N54's are starting to drop like flies - seem to be several new threads a week about it - seems like most people have in the 60-80k on their car. The pump itself has been redesigned twice and is more reliable and less of a problem on the newer cars. It fails as often if not more often than the e46 did at about the same mileage or less but is about a $1200 repair instead of $400 on an E46 and the e46 failed a little less abruptly and didn't cut all the power to the car.
As a data point BMW has not built a reliable water pump since the E36 came out for the 6 cylinder engines. Most fail at 60-90K miles and these are mechanical pumps for the E36 and E46. This is nothing new for those of us that have owned the 3 series for well over 20 years. Surprising no but disappointing yes...
Not trying to be argumentative, but I thought I recalled that you have a GIAC tune on your car. Isn't the water pump motor a variable speed unit, and wouldn't a tune cause the pump to generally work harder due to increased temps?
Water pump failure on BMWs is nothing new. It's also not really a safety hazard.
I've seen these pumps either fail electrically or from the magnet casing cracking/swelling, seizing the impeller.
I understand the car gives you little warning to stop and pull over, but it doesn't engage the brakes or anything. You can still coast off to the side.
Most people complain when they are in the left lane and the car cuts power. If people are driving how they are suppose to be, with multiple car lengths between them in the left lane at 75 mph, then this will give ample time for people behind you to react and for you to pull over.
The problem comes when people hog the left lane and people taillight gate so they can pass. But when your pump fails and your in front, you obviously don't have room to slow down or the ability to accelerate. Fault is on both parties but if people would just stay out of the lane except when passing, this wouldn't happen nearly as much as it does.
Ever notice these cases are mainly US based? If you go to other European forums, it's not as common for people to complain about being trapped in the left lane. Why? Because people know how to drive in Europe...they understand the concept of keeping right except passing.
I just checked Consumer Reports, and yes WP failure is quite common. But then I looked up my old Toyota RAV4 and guess what? Water pump failure common on those too at the same age, along with the Camry, etc. Big deal.
And yes, so many things would work so much better here in the U.S. if people would just STAY TO THE RIGHT on highways unless passing. Driving in Germany was a real eye-opening experience as to how things can and should work.
Also, some Japanese cars have the water pump exchanged by default when they change the timing belt. It's one procedure. Hopefully it is done regularly.
So it isn't quite fair to compare one of those to a BMW where you don't do that sort of thing.
I also wonder where the "cuts power" comes from. I think it'll happily run with the "coolant level low" warning light. The temperature gauge might or might not reflect a problem. Of course you ruin the engine if you continue driving but I don't think that the engine switches off.
My WP failed at ~50 K miles when it was ~6 years old......just barely merged onto highway and the yellow then red lamp popped on. Lost engine power and limped to side of the road.
Both items are shxt... they fail as early as 25,000km
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
