BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#476
working on a e60 and want do some relearning and maybe ecu flashing
installed e-sys too, but in the read me they say replace the inpa folder. if i replace the inpa folder both progs are useable? (inpa and e-sys)? |
#477
For your E60, you will use SP-Daten files with NCS Expert for coding and WinKFP for flashing. You can also use INPA and Tool32 (part of EDIABAS) for diagnosis.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#478
Hi Shawn,
Just bought a 2013 F10 520i , could you send me the links for esys and psdzdata? Thanks. |
#479
Deleted-not sure why there was a double posting....
#480
PM sent.
#481
Hey Shawn,
Just picked up an F30. I appreciate all the knowledge that you've instilled in this thread. Can you throw a brother a bone and send me the link for the latest E-Sys and PSdzData files? Thanks Bro |
#482
PM sent.
#483
Hi, I would like to cody my car f02 and require the link for direct download as the torrent takes time
Kindly send me the link for PSDZData please along with necessary links |
#484
http://www.bimmerfest.com/forums/sho...=1#post7577366
#485
shawnsheridan
Can you send me the link for the latest E-Sys and PSdzData files? Thank you !
#486
PM sent.
#487
so how do i import the sp-daten to ncs expert?
what files do i need for winkfp? |
#488
to copy the files from SP-daten-E##\SGDAT to C:\NCSEXPER\SGDAT (they're not separated into different chassis in NCS Expert, so you just want to copy and paste everything to that directory. Overwrite everything it asks about). The last step to fully updating the install is copying the files from SP-daten-E##\ECU to C:\EDIABAS\ECU. For WinKFP it uses the same SP-Daten files as NCS Expert. Just make sure your SP-Daten includes and has all the files in the Data subfolder for you chassis (e.g. \E89\Data).
#489
when i start winkfp tool 32bit, this apears
PABD no data found im sorry if im bothering you, thank you |
#490
PABD no data found and if i open inpaloader, i cant select any chassis like e60, none of them are seen. im sorry if im bothering you, thank you Last edited by oly2; 05-13-2013 at 03:56 AM. |
#491
Is your SP-Daten structured like this? C:\NCSEXPER\DATEN\E60 C:\NCSEXPER\DATEN\E89 ...
#492
yes its showing chassis and its structured so C:\NCSEXPER\DATEN\E60
#493
Looks like this is still seeding. Thanks for the upload!
Once I get it all, I will continue to seed on my seed-box. Maybe forever? ![]() Thanks again! |
#494
Sorry, then I do not know what the issue is.
