Need some help .. The other day .. I was up on a very steep incline road ... I had the AC on and started up the incline ... before I moved forward the car slight rooled backwards .. like a manual car would do on a step incline ... all of sudden ... my dash indicated Trans Failsafe Prog .. Car had a hard time moving ... I pulled over and shut her down ... then restarted the vehicle ... Trans Failsafe Prog came on quickly and disappeared ... I was able to move normally and drive her home without any problems or any message popping up .. Started the car today .. and no message ... I will go home tonight and take her for a spin to see if I get the message again ... Would rolling backwards would create this message ?
I had reviewed the search ... I will have codes read to determine the exact cause of this message. In addition, i was wondering what are some of the results with others who had this issue. Did you have to rebuild your Tranny or was it just connectors, or cables ... or something really minor ? Please share your outcome. Thanks!
