I have a 2003 330CI Manual around 90K right now and reaching 100K not too far away... had it serviced around 85k, just oil change and a timing belt or some kind of belt. Also, what does this 100K covers by the way, besides brakes and oil change. Got the extended warranty from bmw dealership when my bro bought the car. I know that anything electrical is not covered because it is 100k Maintenance...my question is can I bring my car in and tell them to replace everything that is covered under the warranty right now when it is not service time yet.
First off extended maintenance and extended warranty are two different things. The BMW extended maintenance plan covers manufacturer recommended maintenance based on the car's service indicator system, so no you can't just go in and say you want them to take care of everything.
I have a 6yrs/100K Extended Service Warranty (3rd party) that covers everything on the car and I mean pretty much everything.
I also have a 6yrs/100K Maintenance Warranty that covers all the maintenance work needed such as oil changes, brakes, belts, Inspections I & II, ect....
I took my car in at 99,650 miles to have then perform the 100,000 scheduled maintenance and had the following things done:
* Changes all four O2 sensor
* Changed Spark Plugs
* I was going to have them replace the "lifetime" transmission fluid but it was already changes at 89K when they replace the Torque Convertor under my extended service warranty.
Also check your service record - to see about getting your brakes bleed and coolant flushed. (Brakes are every 2 years and coolant every 4 years from date of production if I recall correctly).
You could also try to get your fuel filter replace - I tried but they said it's not on the 100K scheduled maintenance list - actually it's not on any of the Inspections either - but it's only $45 for a new filter and takes about 20 minutes to change - pretty easy to do yourself also.
Are belts included on the extended maintenance? My indy told me I need new belts - $220 (inc. labour). I have the BMW maintenance warranty though and thought belts are not covered! Please confirm! :dunno:
My 2001 E46, standard shift is a hand-me-up from my daughter. It was built in Germany while she served in the AF. It has 102K miles and runs great. What preventive maintenance items should I perform at this time? My daughter met most scheduled maintenance items. Sine she moved all over the world, I can't recap what she had done and where. I'm a DIY type and have most tools needed. The water pump and thermostat and housing, serpentine belt are new. The plugs have not been changed. The car gets 28.9 MPG in-town. Suggestions welcome.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
