Ok i bought a 2001 325i. It will start initially and run like crap. I mean barely run. If you touch the gas it dies them will not restart. I jave checked the vanos and maf sensor and cam sensors. But nothing helps. Possibly fuel pump? Anyone have this problem before. I was using my 323 to test against to see if it would create the same problems
Did you scan the car for codes? Did you even have a pre-purchase inspection done on the car?
Might be tears in your intake boots, broken vacuum lines, bad fuel pump, spark plugs, you name it.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
