Those familiar with coding know that we can have the exterior mirrors fold when comfort closing your car. This requires a long press (1 to 2 seconds) of the "ribbed" area of the door handle.
I personally find this delay annoying. I am usually left behind by my wife as I stand there waiting for the mirrors to fold. Now you can get rid of this delay by changing the following code:
CAS->3003 FH MASTER->KMFRT_SCHLIESSEN->Werte=00 (the default value is Werte=0F)
This results in a much faster folding of the mirrors when comfort closing.
This find is good because one of the issues I have been struggling with is the concomitant behavior of the close triggers between the sun shade and the mirrors. I generally leave my sun shade open in the winter months and I hate having it continuously partially shut when I hold the lock a bit too long for the mirrors to fold. Hopefully now I'll be able to trigger the mirror fold without triggering the sun shade close. Great find!
Thanks for the tip! I can confirm that this works on E Series cars too; I did it to my E90 a couple days ago. It's a bit more involved because you have to disassemble the NCSExpert data file in NCSDummy, override the value and then reassemble it. After that just save the trace file as .MAN and write it back.
Guys that did this code. Does it also make the key fob also close the mirrors faster? There is also a delay when the mirrors close with fob. Wondering if this change also effect it?? Anyone
I never close my car with the FOB, so I have not notice if this change makes that FOB folding faster. I would suspect it does. I will test later today.
Niiice!!! I hated the fact it took so long with keyfob! Thanks for testing it. You the man. This should be pretty easy for the E series like Merlosso stated. Some nettodat coding should take care of that . We owe it to you for such a great find!!
And there is the same possibility for Comfort Open.
Pressing the "open" key on the FOB for longer than 2,5 seconds rolls down the windows and opens the sunroof.
Comes in very handy when the car was parked in bright sunshine all day long and heated up to diabolical temerature (especially when black/black).
So 2,5 seconds seem like an eternity.
It is in CAS /3003 / KMFRT_OEFFNEN, default set to hex 19, I reduced to hex 0A (1 Second) which suits me better )
all statements below related to Data 48.2, F07, all Values (WERTE) in hex.
the delays are as follows
CAS / 3003 /
KMFRT_OEFF_HINTEN --> Delay between opening front / rear windows, default = 05
KMFRT_OEFF_SHD --> Delay between opening rear windows and SunRoof, default = 23
Since apparently all WERTE settings are hex and in 1/10 seconds this means 3,5 seconds before the roof starts to work.
Same applies to closing
KMFRT_SCHL_VORNE --> Delay between closing rear then front windows, default = 05
KMFRT_SCHL_SHD --> Delay between closing front windows then SunRoof, default = 23
Hey I just programmed my car, reducing the start of comfort open/close to .5sec and everything else to zero. The idea being that everything happens at once, after a half second press.
This works perfectly for closing. But for opening I still get a 3.5 second gap between windows and sunroof.
there IS a reason for the default delays between powering windows front/rear and sunroof and thats why I'm not going to tamper with those.
Just with the initial delay.
Anyway, even when shortening the delay between windows/sunroof action it still is necessary to keep the button pressed until everything is opened/closed.
So I decided to leave it to the professionals (hopefully thinking that they know what they were doing when prrogramming the whole thing in the first place) to leave those intermediate delays alone.
might be somewhat related/unrelated to the topic, but has anyone figured out how to reduce delay from closing the door and to locking the door with comfort access? I searched a bit and it seems like 2010/11 cars coded with latest software got it fixed so I'm assuming it's in the CAS setting somewhere...
Was helping a friend to code his ride, found the FDL in CAS>3003 FH_Master>KMFRT_SCHLIESSEN> changed wert to 0A (1.0 sec, instead of the default 0F=1.5sec)
After FDL coding, still couldn't fold the side mirror.
I found out subsequently from my friend that he could never fold the mirror using comfort access (door handle). He could however close the soft-top, mirror & fod mirror using keyfob.
What else that I need to code to have the mirror fold with comfort access?
For 5, 6, and 7 Series Fxx cars, you need to also FDL Code FRM:
FRM = > ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv
CAS = > KOMFORTSCHLIESSUNG_FB = aktiv
CAS = > KOMFORTSCHLIESSUNG_PA = aktiv
CAS = > KMFRT_SCHLIESSEN = Werte 0A
First the front windows should begin to close, then the rear windows, then the sunroof. To reduce the delay you have to set two or three settings.
CAS/3003/KMFRT_OEFF_SHD set the time between rear windows and sunroof
CAS/3003/KMFRT_OEFF_HINTEN set the time between front windows and rear windows
There should be also a delay for the front windows (nearly like the same for closing the windows and to fold the mirrors). This should be in CAS/3003/KMFRT_OEFFNEN
Thanks for the attempt but like I said I have closing working fine. I still have a delay between front window and sunroof on opening.
And I don't have rear windows because it's a coupe. Your options keep referring to rear window to sunroof delay. Not sure what to do.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
