When I cycle my key to the 'ON' position, all the dash lights light up except the Check Engine light. My car is having trouble passing emissions so I'd like to know if OBC is turning on the light or not. Is there a way the previous owner could have disconnected it but not the other lights? Fuse?
The light is burnt out , I WOULD say a fuse but if your SRS light, your Brake service light, and all those light up then I would say it is not a fuse but a bulb problem. If it was a loose connection then none of your lights on the dash would work... since the dash is set up the same (general) way the brake light housings are. :dunno:
Any sensor can go out at anytime for any reason. I have also heard that sometimes when you replace one sensor on the car the brother sensor will go out. I don't know if that is too common ( I was told it happens more on the E30's)...
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
