Those bolts worked fine? The bolts are $1.83 on this website? Check my posts for future reference. That could be the reason why my tranny had shifting problems the first go around. The Indy told me the fluid was low because of the leak. I knew he underfilled it. So chances are that the tranny takes more than 6 quarts. Bav auto and the others tell you 6. It is always wise to order more. As for the 2-1 harsh downshift, here is something that may help. It worked on my car.
SUBJECT
Harsh 3-2 and/or 2-1 Downshifts
MODEL
E65 and E66 (7 Series) 745i and 745Li with N62 and GA6HP26Z transmission
Vehicles from SOP up to 03/2005
SITUATION
IMPORTANT:
Depending on the production date of the vehicle; there are different situations, and corrective measures, that
must be carefully followed. Running production changes in vehicle hardware and software divide these
situations into three distinct production periods.
A. For vehicles produced from SOP up to and including 02/2003:
***56256;***56443; Harsh 3-2 and / or 2-1 downshift when slowing to a stop
***56256;***56443; Harsh downshift when accelerating at highway speeds
***56256;***56443; "Clunk" noise during a 2-1 downshift while driving slowly to a rolling stop, or during load reversal
as described in SI B24 14 07 and SI B26 01 06.
B. For vehicles produced from 03/2003 up to and including 08/2003
***56256;***56443; "Clunk" noise during 2-1 downshift while driving slowly to a rolling stop, or during load reversal
C. For vehicles produced from 09/2003 up to and including 02/2005
***56256;***56443; Harsh 3-2 downshift when slowing to a stop
as described in SI B24 14 07 and SI B26 01 06.CAUSES
EGS software calibration
Driveshaft guibo coupling deterioration for "clunk" noise complaints
CORRECTION
For Situation A: Harsh downshift complaints
1. Verify that the transmission fluid level is correct.
SI B 24 17 07
Automatic Transmission
July 2007
Technical Service
Page 1 of 3
http://www.bmwtis.com/tsb/bulletins/bulletin_graphic_temp/B241707g.htm 11/9/2007
2. Perform a "Short test" and correct all Drivetrain related faults first.
3. Submit a Puma case titled "Coasting Jolt" to obtain the access code needed to complete the retrofit
reprogramming of the EGS module.
4. Start a Progman session using only V26.1.1 or higher and select "Coasting Jolt" from the retrofit options
menu. The measures plan should indicate a higher programmed number and an EGS calibration change.
5. Clear the EGS adaptations after programming is completed.
For "clunk" noise complaints, vehicles produced 10/2002 up to and including 02/2003, inspect the driveshaft
guibo coupling for deterioration or separation as described in SI B24 14 07.
For Situation B: "Clunk" noise complaints
1. Verify the complaint
On vehicles produced from 03/2003 up to and including 08/2003 the only repair is to inspect the driveshaft
Note:
There are not any further EGS software changes for vehicles in this production period.
For Situation C: Harsh 3-2 downshift complaints
2. 2. Perform a "Short test" and correct all Drivetrain related faults first.
3. Submit a Puma case titled "Urban Program" to obtain the access code needed to complete the retrofit
4. Start a Progman session using only V26.1.1 or higher and select "Urban Program" from the retrofit
options menu. The measures plan should indicate a higher programmed number and an EGS calibration
change.
For "clunk" noise complaints, vehicles produced 09/2003 up to and including 02/2005, inspect the driveshaft
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Please refer to the latest KSD for all applicable labor operations and allowances.
If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used.
Page 2 of 3
Defect Code 24 00 39 61 00
[ Copyright © 2007 BMW of North America, LLC ]
Page 3 of 3
