2F7B oil pressure sensor switch - Bimmerfest - BMW Forums
Old 06-19-2017, 02:08 AM
rnbguy rnbguy is offline
Mein Auto: f30
Hi All,
I'm seeing this error, 2F7B , does anyone know where these are located on the n63?
Also are there any symptoms of the oil pressure sensor switch failing?
Mina
Old 06-19-2017, 04:21 AM
Doug Huffman's Avatar
Nuclear engineer
Mein Auto: 2012 Feb 11 X5 35d (E70)
I read your error code as 'Improbable Value'. The oil pressure switch biases a 'transistor' in the ECU and should be either 12 VDC high above ground OPEN or pulled down to 0 VDC ground potential CLOSED on low pressure. Likely the ground is defective with high resistance to ground giving an intermediate output.
The pressure switch is a pretty simple vital protection for the engine.
Replacement location
https://www.newtis.info/tisv2/a/en/f...uge/1VnXf5PcH5
I am responsible for what I write, not for your understanding of it.
Old 06-19-2017, 04:48 AM
Mein Auto: f30
perfect thanks!
Old 06-19-2017, 05:07 AM
Nuclear engineer
Glad to be of help. Tell us what you find please. Resistance across the contacts, or case to contact, removed from the engine should be ~0 Ohms
