What are the sings of a blown head gasket?? E46 - Bimmerfest - BMW Forums
Old 08-07-2009, 12:47 PM
JPMONKS JPMONKS is offline
Mein Auto: BMW 318i
I have a coolant leak I have just discovered..and the car overheated for approx 5 mins! Is is true that the big rubber hose that comes from radiator into engine, if that is hard that means the head gasket is blown!...Is that true? as it felt hard enough it was quite hot.. I havent seen any whitesmoke either from exhaust..
Please help! How much would it be if the head gasket was blown??
Old 08-07-2009, 12:49 PM
akhbhaat akhbhaat is offline
In vino veritas
Mein Auto: German Civic
The most obvious symptoms are "milky" (coolant saturated) oil and white smoke (evaporating coolant/water).
If that's the case, get some lube. It's not a cheap repair and not something that most people can DIY. My buddy paid out something like $2500-3000 USD to have the head gasket replaced on his E36 M3 (I'm sure there are shops that will do it for less, but it's going to be expensive regardless).
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
Old 08-07-2009, 12:56 PM
Mein Auto: BMW 318i
I dont know if it is blown but If I started it at anytime would there be white smoke for instance? Would the oil be watery/nilky now for instance if I checked...
I heard its quite expensive..this is the second issue with coolant leaking.
Cheers for the help dude
Old 08-07-2009, 01:09 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & ST 335i
Head gaskets are so easy to replace and cost like $20-40s plus the head gasket glue for like $5s....
If you ever need to replace it just DIY it.
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
BMW 2006 M3 - stock - SOLD
Old 08-07-2009, 01:10 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Um... NO.
I believe you are thinking of a valve cover gasket.
HEAD gaskets are a very involved job.
Old 08-07-2009, 01:13 PM
TheMalibuMafia
Originally Posted by KrisL View Post
Um... NO.
ahh yes.
Valve that is what I was thinking of. thanks kris
TheMalibuMafia.com
Old 08-07-2009, 01:22 PM
In vino veritas
Should be, yeah - at least with the milky oil. If your oil is dark and unclouded, you're probably in the clear (at least for now). If that's the case, I'd still keep checking it for several weeks just to be sure. Overheating the engine is no joke - but for all I know, the four pot engines might be more resistant to it than the six pots.
From what I remember with my friend's M3, there was a little smoke at first, and it became progressively worse over time. The smoke/exhaust fumes should also have a "sweet" rather than pungent (e.g. burning) odor.
Old 08-07-2009, 02:00 PM
Mein Auto: BMW 318i
Cheers as checked car there and there is no smoke nor is there milky consistency in the oil..and there is no white smoke..thank god..but will keep a very close eye on it..it gave me a kick up the a@s no doubt as will get it sorted asap..
Cheers guys!
Old 08-07-2009, 02:04 PM
Mein Auto: BMW 318i
Cheers appreciate the answer it has relieved my fears somewhat knowing that the car is showing no signs of the above..
Thanks again,
JP
Old 08-07-2009, 02:05 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
ahh yes.
haha
THIS is a DIY for the headgasket...
http://www.pelicanparts.com/bmw/tech...ead-Gasket.htm
Old 08-07-2009, 02:30 PM
stox111us stox111us is offline
Mein Auto: 2000 BMW 328i
SJ this stuff is great but I think, if this gets screwed up. It will be even more expensive to repair. Pro is the way to go.
Old 08-07-2009, 02:36 PM
Solidjake's Avatar
Zero. Leaks.
Yup. My headgasket went on my Land Rover Discovery. I paid 900 to get it done.
Old 07-11-2014, 01:03 PM
soccerpapa's Avatar
soccerpapa soccerpapa is offline
Mein Auto: 05 e46, 06 e61, 17 f48
please help me...
sorry but I think this post is worth being brought to life.
Is constant low coolant a sign of bad head gasket? my e61 needs 750ml of coolant mix every 650 miles, about a week worth of driving...
no other symptoms of issues, made an appointment with dealer for end of month, but currently I just add more coolant.
thanks a lot.
Um... NO.
Old 07-11-2014, 01:59 PM
TheMalibuMafia
thanks a lot.
No. Just sounds like you have a coolant leak some where.
TheMalibuMafia.com
Old 07-11-2014, 02:26 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Agree. May only leak when it comes up to temp and if its out of sight, you won't see it without getting under it, and it can drip off while moving and/or evaporates on the car while stopped.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 07-11-2014, 02:31 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/05 X5
Thats one of the drawbacks with that shield being there under the engine. It can hold a very large amount of fluids. So if its leaking somewhere that shield can catch it from your not going to see a leak on the ground at all.
Old 07-11-2014, 05:51 PM
soccerpapa's Avatar
thanks guys, maybe i shall jack up the car and check the under cover for more...
Old 06-16-2017, 12:25 PM
pgib8 pgib8 is offline
Mein Auto: 325i
since this thread comes up in google search i'm adding something important.
a blown head gasket does not necessarily mean that you are getting white smoke from exhaust or that you have strange looking oil (mayonnaise). the head gasket can fail in many different ways, in this case it sounds like high cylinder pressure is being pushed into the coolant but not the other way around. this is essentially pushing out your coolant and the coolant hose will be very firm too. there are certain tests you can do, one good one is the block tester. a blue fluid in a special device that goes onto the expansion tank. as you run the car, air and what not is pushed through the fluid. if the fluid turns yellow, it means there are exhaust gases too, which indicates a blown head gasket or way worse it could be a cracked head.
doing the head gasket is super time consuming which is why it costs a lot to get it done.
if the engine overheats even for 1 second it could mean very bad news. the head may have warped and in the process the head bolts may have stripped the threads in the block. this means even when you put in the new head gasket you may not be able to torque down the new bolts anymore and you will have to go through a whole other procedure which is even more work.
before your coolant got too low and your engine overheated, you should have seen a low-coolant light come on and you should have pulled over within like the next few minutes and definitely kept your eye on the temperature gauge.
Old 06-16-2017, 12:38 PM
GermanAutobahn GermanAutobahn is offline
Mein Auto: 325xi
Park it....Pay the guy who knows how to fix it...and go on with your life.......
