Old 06-16-2017, 11:02 AM
RMDman RMDman is offline
Mein Auto: 330Ci
Overheated now won't start
Hello all,
My 05 330 Ci overheated on my way home. I pulled into a gas station and let it cool off. Being it was dark and I had no tools I called for a tow and had it taken home.
Now it will crank but not start. I pulled codes and got P0300, P0303, P0306, P0117.
Any ideas?
Thanks in advance.
Old 06-16-2017, 11:15 AM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
The p3xxx codes were thrown when the engine was still running so they aren't relevant.
P0117 says the engine temperature sensor is shorted to ground. I don't know if this would prevent starting.
Try disconnecting the sensor.
2010 BMW 550i MT
2003 BMW 325i @195k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 06-16-2017, 11:17 AM
Mein Auto: 330Ci
Thanks for a quick reply.
Can you direct me to the temp sensor. I'm not new to cars...just to THIS car.
Old 06-16-2017, 11:30 AM
acoste's Avatar
There are 2 of them:
http://www.realoem.com/bmw/enUS/show...diagId=11_2201
http://www.realoem.com/bmw/enUS/show...diagId=11_2169
2010 BMW 550i MT
Old 06-16-2017, 11:34 AM
Mein Auto: 330Ci
Thank You.
Old 06-16-2017, 11:52 AM
FredoinSF FredoinSF is online now
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
How far did you drive it while it was at higher than normal temp? Any sort of overheating is the kiss of death for this engine.
Old 06-16-2017, 11:54 AM
Mein Auto: 330Ci
just drove it about 1/4 mile slowly with alot of coasting...
Old 06-16-2017, 12:02 PM
acoste's Avatar
My 528i survived couple of gently driven miles with a stuck closed thermostat.
The temperature sensor has a negative temperature coefficient. Low resistance means high temperature. My guess is, due to the short the DME thinks the engine is hot and it doesn't inject enough fuel to start the engine.
Check the engine temperature in the hidden menu of the instrument cluster.
2010 BMW 550i MT
Old 06-16-2017, 12:05 PM
acoste's Avatar
Maybe yours didn't overheat, just the temp sensor went crazy.
2010 BMW 550i MT
Old 06-16-2017, 12:48 PM
Mein Auto: 330Ci
Thank You...Acoste.
Old 06-16-2017, 01:11 PM
GermanAutobahn GermanAutobahn is offline
Mein Auto: 325xi
You are describing a seized engine...due to catastrophic 'over-heat' and combined oil viscus starve....however short lived.
Anything...and everything...is NOW within grave question for the integrity of your BMW engine.
If you are an Irishman...you might have LUCK!
Old 06-16-2017, 01:23 PM
Fast Bob's Avatar
Keeping it surreal
Pull the plugs, and try to rotate the engine by hand, see what happens....
The road goes ever onward....
(R.I.P. Jever)
Old 06-16-2017, 01:41 PM
Mein Auto: 325xi
I too am hoping here!
Depending on his skill, he may find the way to turn the crank.
Honestly, it is a challenge to find any entry to actually turn the crankshaft on not only BMW but almost if not all modern cars today.
If he is not a moderate back-yard mechanic, he needs help.
Old 06-16-2017, 02:04 PM
Mein Auto: 330Ci
Thanks for all the input. Let me repeat the symptoms. The engine WILL crank and sputter as if it will fire. I tried to crank while the accelerator pedal was floored to get maybe a "limp mode" start. to No avail.
I have many years of experience with cars and do my own work on my others. This BMW is new to me. This engine is most certainly NOT seized. There is no evidence of coolant in the oil nor oil in the coolant.
While I cannot rule out a blown head-gasket or warped head, I'm intrigued because the engine appears it is attempting to start.
Thus the inquire ....I'm just wondering if there is some simple issue indigenous to BMWs that I'm not aware of. I have intention to try disconnect of the temp sensor as advised by acoste. I will have to go to the cars location.
Thanks again to all who offered info.
Old 06-16-2017, 02:41 PM
acoste's Avatar
Easier to read the temperature on the hidden menu first before disconnecting it because it is underneath the intake manifold. Hard to reach.
According to the wiring diagram, the one in the rear under the intake checks the coolant and the one on the oil filter housing checks the oil temperature.
2010 BMW 550i MT
Old 06-16-2017, 02:45 PM
Mein Auto: 330Ci
OK now guide me to this hidden menu...lol
I've had this car for only 3 days...It may be a blessing or a curse....
Old 06-16-2017, 02:48 PM
acoste's Avatar
http://forum.e46fanatics.com/showthread.php?t=239619
2010 BMW 550i MT
Old 06-16-2017, 03:00 PM
acoste's Avatar
the temperature displayed there is in Celsius
2010 BMW 550i MT
Old 06-16-2017, 03:17 PM
Rusty34's Avatar
Rusty34 Rusty34 is offline
Mein Auto: 2016 550i M-Sport~2015 X1
When you are cranking the engine is the sound it makes while turning over about the same as before the incident.
Sent from my SM-N920V using Bimmerfest mobile app
Old 06-16-2017, 06:17 PM
Mein Auto: 330Ci
Yes Rusty...the cranking sounds are normal. Nothing metalic. NO knocks, bangs, tapps or clunks.
If not for the overheating, this would be a nondescript crank/ no start issue.
Perhaps I should look at it as such. Being unfamiliar with BMWs I was wondering if there was some odd occurrence that was common such as ( when overheated, the CPS fails and the result is a no start. For example.)
Thanks to all for your input. This forum has offered info much quicker than any other I am member to.
Old 06-17-2017, 05:09 PM
Mein Auto: 325xi
I'm lost too. Good that it is not seized shut, but damages detrimental should not be ruled out.
An examination, or survey, by qualified, should be a next move. Here you will receive a good news, or bad news report...and you will have to pay to get this info...but you need to know whether to bait or cut bait! I'm rooting for you...Good luck
