Old 05-30-2014, 10:59 AM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by 528i black-E View Post
I had the same problem going up hills, so i did a transmission tune up,on my 2000 528I,now it runs smooth, I used castrol multi vehicles. I have a GM transmission with Dextron 3.. Make sure you have drained all oil on the torque converter and transmission,make sure you changed the filter and when filling back with new oil make sure your car is label to a straight position to get the accurate quantity of oil in your transmission!!!.
How did you get the oil out of your torque converter ?
The road goes ever onward....
(R.I.P. Jever)
Old 05-30-2014, 01:58 PM
Caver Dave Caver Dave is offline
Teufel Hunden
Mein Auto: 2004 330xi
2004 Titanium Silver 330xi Auto @ 188k - *New* Bosch Alt (130k), G.A.S. DISA kit & 1.2bar Billet coolant cap, fuel filter (133k), Valve Cover Gasket (140k), VDO FuelPump (143k), Giubo & CSB (144k), Cooling System Refresh, CCV, OFHG (155k)
2004 Ford F-350 4x4 C&C w/ 9' steel flatbed, 6.0L early stages of de-alphabetizing
1972 Jeep Commando - AMC304 w/ TBI, TH400, Lifted, locked 4.27s, caged, bumpers, winch, 140A alt, OBA & airhorn... slightly modified for occasional offroad use
Old 04-22-2015, 06:58 PM
evanr614 evanr614 is offline
Mein Auto: 2000 328Ci
Starless, I have had the same issue after flushing and filling with Redline D4 in my GM tranny. I'm going to pick up a ton of Pentosin ATF1 and re-flush and will most likely never touch it again.
Old 04-22-2015, 07:23 PM
Fast Bob's Avatar
Keeping it surreal
You do know that there`s a big difference between "flush", and "drain & refill", right ?
Also, that about 40% of the old fluid remains inside the TC, which is why a D&R needs to be repeated 2 or 3 times to get as much new fluid as possible into the system.
(R.I.P. Jever)
Old 04-22-2015, 07:24 PM
Fully aware. By flush I meant 3 drain and fills. Hence the "tons" of fluid.
Thanks dude
Old 04-22-2015, 07:28 PM
Fast Bob's Avatar
Keeping it surreal
Thanks dude
Good luck with that, I hope you get better results this time around !
(R.I.P. Jever)
Old 06-17-2017, 07:27 PM
timberwolf5 timberwolf5 is offline
Mein Auto: 2010 328 xi
Hi guys,
I also had a bad experience replacing my GM tranny with valvoline dexron VI fluids. I did my transfer case at the same time.
Whats interesting is that my drive to the BMW dealer ship to get my transfer case reset was smooth as butter. After resetting the transfer case my bmw became sluggish. I think the BMW tech reset my transmission adaptations too (because I mentioned to him that I changed the tranny fluid. He may have reset the transmissions adaptations as a favour). My BMW shifted like a bucking a bronco after going to the dealership.
Maybe its not the fluids and its the transmission adaptations reset that's the culprit.
Nevertheless, one year later I have become used to the hard shifts. It has also improved over time (transmission self adapting?). It also improved after I did a second flush and refill. However, the car does not feel like it did before I changed the fluids the first time.
Oh well this is a starter BMW (2010 328xi). I'll be upgrading soon. Give this one to the future wife maybe.
Old 06-17-2017, 08:54 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Originally Posted by timberwolf5 View Post
Hi guys,
Try the E90 forums?
Old 06-17-2017, 09:25 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
Hi guys,
Ironically enough I feel the same sluggishness after resetting adaptations. You'd think it will be the opposite.
You know there is a saying "do not fix what's not broken".
Good news the car will relearn the adoptive values in a few days and will be fine.
