Old 06-17-2017, 06:43 PM
Aymaar Aymaar is offline
Mein Auto: 2011 328i
Aftermarket radio won't save memory
Hi I got a soundstream double din installed in my 2011 328i and whenever I turn on the ignition the radio doesn't turn on(I have to manually turn on) and doesn't save any presets. I've had it taken to an audio shop multiple times, where they tried switching the red and yellow wire, and I've had the results
I've noticed that if you turn the radio back on within a short amount of time that it will turn on with the ignition and save the memory but if you leave it off for a couple hours it will reset. Could that have to do with sleep mode ? And can I do anything about it ?
Old 06-17-2017, 09:28 PM
Originally Posted by ctuna View Post
Most likely you haven't found a constant on voltage source.
head unit
http://www.e90post.com/forums/showth...ight=head+unit
http://www.e90post.com/forums/showthread.php?t=1036190
http://www.e90post.com/forums/showth...hlight=dynavin
http://www.janus-design.net/english/
http://www.e90post.com/forums/showthread.php?t=355089
http://www.e90post.com/forums/showth...light=retrofit
http://www.e90post.com/forums/showthread.php?t=993447
http://www.e90post.com/forums/showthread.php?t=1016187
https://www.bmwgm5.com/Logic7_E90_91_92_93.htm
First post should set you up.
Be sure you have a strong battery to .
If the battery is weak and drops below the minamum voltage on start up that can cause it also.
I don't know much about cars, what exactly would I need to buy, and ask the people at the audio shop to do ?
Old 06-17-2017, 09:53 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
It they can't figure it out go elsewhere .
The first link tells you what to do may be you could have them
read that assuming they can read. Print out the first link and
take it to them there job is not done.
If they know anything about BMW's they should have been able to
figure it out.
There must be someone in the LA area that no's how to install stuff correctly .
Old 06-18-2017, 07:35 AM
wilt wilt is offline
A radio needs a constant voltage source to preserve its memory (and run the clock often found in the radio).
A BMW E9n normally turns OFF voltage to almost all demand sources after it is locked, it only keeps voltage supplied to a very few items (such as the module that senses a keyfob's unlock signal, or the CAS fob proximity so it responds to touch unlock)
Your installer failed to connect the radio memory supply line to a constant voltage source in the BMW, they should have known better.
double-din, ignition, memory, problem, radio, sleep mode
