Brake Replacement Time - Linear Braking - Bimmerfest - BMW Forums
Old 06-18-2017, 10:46 AM
GTIto328i GTIto328i is offline
Mein Auto: 328i
Exclamation Brake Replacement Time - Linear Braking
My pads are almost down to 3mm and will be pulling the trigger on a full brake job soon. Got a quote from an indy garage for roughly $1k for both front and back (rotors, pads, sensors) with OEM parts.
One of the very few things I miss from my old GTI was the linear brake feel and the stopping distance. I know that the RFTs on my 328i are no match for the summer tires I had on my GTI, but looking to see how I can improve braking performance with the tires I have.
One of the thing the garage suggested was that I should consider upgrading to Stoptech brakes. Approx $600 more but they claim its going to be lot closer to what I was used to.
So looking for thoughts and ideas? Note that when I got the car, the pads were probably didn't have a whole lot of meat on them. So it's possible that with a new OEM set, the brakes are going to be just as good, if not better, than my GTI.
Questions:
1. People who drove/are driving the GTI and had/have F30, with a new set of OEM brakes, are the cars comparable?
2. People who upgraded their brakes to Stoptech and/or other brakes, what are your thoughts about the extra $$ spent?
PS: I did my brake fluid flush per schedule. Also, car is a Luxury Line with 416 style wheels, just in case that matters.
Old 06-18-2017, 01:16 PM
Wgosma's Avatar
Wgosma Wgosma is offline
Mein Auto: 2000 528i M-sport 5spd
$1K for parts/labor on all 4 corners looks like great price.
Bet the new pads/rotors greatly improve stopping power. Personally I'd stick with OEM setup if this is a daily driver and you don't auto-x or track the car.
Also suggest you DO NOT 'bed' your new brakes via StopTech's (or others) procedures; unless you live in the sticks it's difficult to find enough 'runway' to employ repeated speed-up, slow down cycles required to properly heat and cool the brakes. Stick with the 'go easy on the brake pedal' for 250 miles or so and you're good.
Bill
Sent from my iPhone using Bimmerfest
Bill / Oceanside, CA
00 528i - 5 spd M-Sport
Old 06-18-2017, 01:32 PM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
New pads, rotors and a brake flush should give you close to a new car feel IF tires are in good condition and suspension is still reasonably tight.
Most newer car brakes are linear in application. It's wear that causes them to feel inconsistent, grabby or soft.
Old 06-18-2017, 02:53 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
That's good advice. And look, OP, you can do for $500 as [pads + rotors + sensors + new brake fluid] are among the easiest jobs for the Shadetree Mech.
Dude it's Summer! Git yer hands dirty....get t'know your ride.
Old 06-18-2017, 03:17 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
Mein Auto: 2008 535i
If you like the original BMW brakes, get the OEM ones if you can swing it.
Them suckers saved me from an accident with a fire truck, so I stayed with OEM, which my indy recommended. The bill is paid and gone, so I don't think about it, but the brakes stayed as good as new.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 06-18-2017, 03:18 PM
Robin128 Robin128 is offline
Send a message via ICQ to Robin128
Mein Auto: 340i M Sport 8AT
Check your suspension bushes while you are at it...how many miles has your ride done?
Whole lot of servicing you can do yourself so long as any warranty allows.
One should treat others as one would like others to treat oneself.
Old 06-18-2017, 03:19 PM
Michael Schott Michael Schott is online now
Moderator
Mein Auto: 2017 VW GTI Sport MT
I considered improving initial bite on my F30 to make it more like the E90. I would have changed to firmer pads and added SS brake lines.
Old 06-18-2017, 05:04 PM
Mein Auto: 328i
Bill
10-4 regarding the bedding, Bill. Just that I have not driven a new F30 BMW. I've driven a bunch of used ones as I was purchasing mine. Mine had 40k ish when I bought it.
I sure hope that should do the job.
One thing I promised never to touch on my cars are the brakes. You know, for safety. I'm open to and have done a few different kinds of installs with youtube help, but this is just too much.
Pretty solid endorsement for OEM brakes. Looking at most replies, it's probably just that my old brakes were soft as I bought them. New install should give me the nice linear brake feel.
At 51k miles now. Suspension was checked around 40ish k when I bought the car. Per inspection, they seemed ok.
Will do some more research on this. So what pads do you recommend?
And stainless steel brake lines like this one? - http://store.uucmotorwerks.com/stain...8dx-p1521.aspx
Thanks!
Old 06-18-2017, 07:43 PM
Wgosma's Avatar
Thanks!
Brake pad and rotor replacement is quite simple/straightforward; sure, if you're not comfortable with doing the work just pay the mechanic. I'm not an auto mechanic but I'm reasonably proficient with a wrench , I've owned 8 BMW's and I always perform my own pad/rotor (and brake bleeding) work - frankly I feel more comfortable driving the car after I work on it than when a mechanic does.
That price of you were quoted is very reasonable if it includes parts and labor.
Good Luck/ Bill
Old 06-19-2017, 12:02 AM
mr_clueless's Avatar
mr_clueless mr_clueless is offline
Mein Auto: 2015 328i M-Sport
Just switching to the M sport's Euro-spec pads would probably help a bit (since OP's car is Luxury line they have US spec pads for reduced brake dust).
2015 328i / M Sport / Alpine White / Coral Red / 4 DR / 6 MT / Rear Camera + PDC / Xenons / DHP / 60K+ Miles / Bought 10-30-2014
Old 06-19-2017, 08:33 AM
It will, however pay close attention to the IF. Slapping performance pads on your car may get you little more than noise and brake dust.
Old 06-19-2017, 09:55 AM
Moderator
Thanks!
I never did it so never chose these components.
Old 06-21-2017, 10:55 PM
Hobie18 Hobie18 is offline
Mein Auto: 328ix
Brake parts pricing vary widely 30-40% for the same products. I have used Rockauto.com for most of my parts needs. I don't change my own oil but always do brakes and tune ups. Relatively easy work that can save you hundreds of $. I started doing them again myself after watching a shop work on my car and was putting inferior thinner rotors on. Why because that's what an auto parts sent them. If I wasn't watching, I would not have known until overheating and warping the rotors months later.
Old 06-23-2017, 08:54 PM
Mein Auto: 328i
https://www.turnermotorsport.com/p-3...8iix/?pdk=BQQB - Decided to get the standard kit. Decent price. Should be $800 installed. (thanks for all the folks suggesting I do it myself. Maybe I should but I cant get myself to do my brakes).
Based on some reading, I was also tempted to pick up this (M sport trim package brakes) but not sure what else is needed to make this fit? - https://www.turnermotorsport.com/p-3...337a/?pdk=AgUB
Old 06-24-2017, 05:23 AM
Wgosma's Avatar
Good luck with the new brakes. If you enjoy wrenching maybe next time give the brake work a try yourself- it really is very straightforward and simple job - one would kind of have to work at it to screw it up.
Bill
Old 06-24-2017, 08:13 AM
lieb923 lieb923 is offline
Mein Auto: ex e30,e39
Take a look at Cool Carbon ST Plus from Bav Auto.
Sent from my SM-G935V using Bimmerfest mobile app
Old 06-24-2017, 08:01 PM
icon5585 icon5585 is offline
Mein Auto: 2014 BMW 335i xDrive
I had a GTI and an S3 and miss the brake feel since getting my 2014 CPO 335i xDrive. The brakes are quite soft and I feel like I have to press a lot harder than I'm used to. Car only had 37k miles on it.
Sent from my iPad using Bimmerfest
