Old 06-19-2017, 05:42 AM
Bloomer85 Bloomer85 is offline
Mein Auto: 335 convertible
Knocking sound heard in trunk
Hello all
I bought a '08 335 convertible to drive in the summe and I noticed a knocking sound coming from the trunk area when going over major bumps, when the top is up. The only thing I can think of is the sliding cover (that has to be pulled out to put the top down) is moving. I noticed one side is a little loose. Everything else seems to be secured in the trunk. Any help would be great appreciated
Old 06-19-2017, 06:05 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Might be bad shock mount. Not uncommon for them to rust out and cause the shock to bounce around in the tower.
I recommend you do both upper and lower mounts for both sides. Might also be a good idea to swap out the stock shocks. Especially if they are near or over 100k miles. Bilstein sells the pair of OE replacements for about $150
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 06-19-2017, 06:11 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Well, have you seen your wife lately?
Old 06-19-2017, 06:50 AM
Could it still be that if I don't hear the sound all the time. The car only has 56k miles on it too. I didn't hear the sound when I first bought it last year or when I took out of storage this year. Started about a month or so ago.
Old 06-19-2017, 07:09 AM
Steve111 Steve111 is offline
Mein Auto: 07 328xi
I had the shock mounts go bad back there and I would hear loud bangs as I hit a big bump. Sounds like that's what you have going on
Old 06-19-2017, 07:32 AM
Cool thanks. I'll give it a shot
Old 06-19-2017, 10:14 AM
It's not so much an mileage thing, but more so age. It's actually not the mount itself but a small cup that the bump stop sits in that rusts. This piece prevents the shock from going through the upper mount though.
Old 06-19-2017, 02:03 PM
budburr66 budburr66 is offline
Mein Auto: 2013 328iX
Let her out!
Sent from my SAMSUNG-SGH-I537 using Tapatalk
