leaking hardtop 335i 2008 - Page 3 - Bimmerfest - BMW Forums
Old 08-23-2009, 02:55 PM
xtremecruiser's Avatar
xtremecruiser xtremecruiser is offline
Mein Auto: 08 335I vert
Originally Posted by johnc_22 View Post
The first time I saw the origami hard top I just thought it looked like something destined for problems and eventually a huge financial burden. I know Lexus, Volvo and other companies have offered hard tops - do they fare any better than BMW?
Just seems to be the E93 series that has issues
Old 08-23-2009, 08:07 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
I don't know about Lexus but as regards the Volvo C70, the dealer I take my XC90 to for service is one of the larger volume dealers in the S.F. Bay Area and they have had zero (no, that isn't a typo, I did mean to type zero) cars in for top leaks. They have had a car repurchased for a failed top opening (it stopped half way open) that went through 4 failed repair attempts. But zero water leaks....
Old 08-24-2009, 08:20 PM
Heard the same thing from other owners and dealers with their hardtop convertibles, seems BMW has the drip drip splash splash issue
Old 08-24-2009, 08:58 PM
nycdoc22 nycdoc22 is offline
Mein Auto: 09 328 vert
My 09 E93 does not leak.
~8000 miles
...But i am scared now...
Old 08-24-2009, 10:08 PM
captainaudio's Avatar
Worlds Foremost Authority
There are cars that are water-tight. But if you have one that leaks, it is a real downer.
My theory is that the seals will work if fit of the top is within certain close tolerances. If it is not then it will leak and there is nothing that can be done to the seals that will cure the problem. What BMW probably needs to do is come up with a design for seals that does not require such close tolerances in the fit of the top. This may not be possible with the present top design.
My signature should explain how I arrived at this theory.
CA
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 08-24-2009, 10:24 PM
CA
I agree with your theory 100%. Which is why I suggested checking out the windshield frame seal of the next gen Z4. There is something like a 1 1/2 inch wide seal that is in turn backed up with what looks like a 3/8 inch wide U-shaped drain channel that routes any water that makes it past the 1 1/2 inch wide seal to drains that are located at each of the A-pillars. I would be quite surprised if the Z4's sealing approach is not implemented on the LCI edition of the E93.
Old 08-25-2009, 11:25 AM
Shark01 Shark01 is offline
Mein Auto: Porsche Turbo, E93 335i
Originally Posted by schoenbg View Post
in response to my complaint, BMW NA did not dispute the leak but claimed it is not their problem because 1) a tree fell on the car (this is not true!)
In my opinion, this is correct (knowing the tree fell on the garage, the rest is semantics). This is no different than a collision scenario......its an insurance issue, not a warranty issue. If the car cannot be repaired to your satisfaction, the insurance company needs to buy it off you.
Old 08-25-2009, 11:34 AM
It is NOT normal for water to come into the car when its raining, I do not care what the dealer told you
Trying to work with BNW's customer relations does not work, lawyer up
This is NOT a BMW or hardtop only issue. ALL convertibles develop leaks over time.....ALL of them. Can't tell you how many seal kits and replacement parts I've bought for Corvettes and Mustangs over the years. Its one of the trade-offs of convertibles
Now if your car develops leaks during the warranty period, by all means try to get it fixed on their dollar, but its no guarantee they won't re-occur.
Now in a small % of cars, tolerance issues may be such that leaks can't be fixed and the car must be sent back to a factory setting (hopefully the owner gets bought out).
Old 08-25-2009, 11:40 AM
If the gap is too great, I don't know what can be done to the current generation of E93 to 'solve' the leaking problem. With my E93, the shop foreman tried shimming the seal on the windshield frame to no avail. If there was going to be a 'solution' shimming would have addressed it. Net, net, even the shop foreman was out of things to try... in that circumstance, a repurchase/trade assist is the only remedy available. Since I had been burned once on an E93 and there was no way to be certain that I wouldn't get another leaking car, I took the cash.
Old 08-25-2009, 01:23 PM
You are right about this and the Z4 change
All the leaky E93's are not fixed by a "shim" and making the top as tight as possible, if you are one of the unfortunate ones with a leaky E93 then you are flocked, BMW can replace the seals, slap gue in the rubber, shim them, and tighten them down so tight that the windows sound like they are gonna shatter, butt it does not fix the issue.
I have yet to hear of one that has been fixed that leaked.
Old 08-25-2009, 01:29 PM
The E93 is a different animal, it either leaks and your flocked or it does not leak.
I have rode through the same car wash in another E93, a 85 mustang Gt vert, a 08 Vette, and a 02 jag.. and none of them leak, only the 85 GT had a few drips.
Old 08-25-2009, 01:36 PM
SailinSand's Avatar
SailinSand SailinSand is offline
Mein Auto: .
Glad to have gotten rid of my lemon.
...not many people have had this same issue. (luckily)
Old 08-25-2009, 01:38 PM
I have read your threads, unfortunately mine issue is close to what yours was
Old 08-25-2009, 01:39 PM
SailinSand's Avatar
Mein Auto: .
I have read your threads, unfortunately mine is close to yours
So sorry to hear that. ...not many of us out here. Did you do a 'Trade Assist?'
...glad to ahve gotten rid of it, however...there are days I miss the vehicle.
Old 08-25-2009, 01:44 PM
Keep an eye out for the LCI edition of the E93. If the seal is replaced with something like what is available on the next gen Z4, you can expect the top leaks to have been resolved.
Old 08-25-2009, 01:45 PM
BMW customer relations jerked me around, they offered me a swap butt the local dealer refused to do it.
I have had to lawyer up, just waiting on my day in court, they can not keep delaying it forever.
Nice to know that the local media will be there to put it on the news when my court date comes, they think its a story worth waiting for
You would think BMW would not want cases like this to get to court, esp since I am a going to be a arsh and press the issue and actually go into court.
Old 08-25-2009, 01:49 PM
I have not heard of any changes with the 2010 model, do you know when its going to happen ?
I know the M3 E93 also has the same leak issues.
Old 08-25-2009, 01:59 PM
Speculation from the dealers is September 2010, which would be MY 2011.
The E93 M3 has the same seals as the non-M E93, so there would be no reason for the M3 E93 to not leak....
Old 08-25-2009, 02:03 PM
Be prepared for BMW to offer you either a trade or repurchase on the courthouse steps. If they offer you a resolution, you can't force them to suffer through a litigation experience. There is no punitive damage provision unless BMW refuses to settle and forces a trial.
Funny, BMW said that this new hardtop was the answer to convertible leaks and it's the new future
Old 08-25-2009, 02:08 PM
Well, it may be the answer, but apparently not without some teething issues.
Old 08-25-2009, 02:13 PM
We will see, BMW NA refused my written and verbal arbitration request, I am sure they enjoyed my 18 page lawsuit from my attorney.
I have had to keep a second car to drive since mine is such a POS
My lawsuit is more involved than just a LL case, I am eligible for damages.
http://www.carlemon.com/lemon/SC_law.html
Old 08-25-2009, 07:00 PM
I skimmed the URL you provided. Where is the section that provides for damages? If I were the attorney representing BMW NA, my first question would be how have you been 'damaged'? My second question would be how have you arrived at your damage calculation? The fact that you have had to keep a second car to drive isn't exactly relevant, since the water leaks don't rise to a safety defect that would justify the requirement for a duplicate/replacement car. Worst case, you can't drive the E93 in a rainstorm, so your damages are the daily rental rate for the number of days it rained between the time you first brought the car in for the leaking roof and the date of trial. If there is an exclusive remedy clause in the SC LL statute, the offer to repurchase the car (absent obstruction or other 'above and beyond' activity) is generally the exclusive remedy that is available to you....
I am not saying that you don't have a case; just that you need to be prepared for a settlement offer that involves either a trade assist on a new BMW or a repurchase of the present car.
Old 08-26-2009, 12:57 PM
I can't discuss the case right now, it's complicated
Thanks for the info about the changes to the Z4 hardtop
Old 08-26-2009, 01:24 PM
pilotman pilotman is offline
Mein Auto: e46, X3
I am an attorney, and I can tell you damages are easily recoverable in these situations, under a number of scenarios, including but not limited to: breach of contract (loss of use, etc. disclaimers for such damages notwithstanding), violation of consumer protection statutes (which provide for attorneys' fees and punitive damages), etc etc etc.
Good luck, sorry you had to resort to litigation but hope you obtain a favorable result.
