E46 (1999 - 2006)
Old 10-16-2016, 02:05 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Coupe windows freezing shut in winter ?
Coupe owners in cold climates probably know what I`m talking about. Our windows normally drop down about 3/8 ths of an inch or so upon opening the door, and automatically raise up the same amount when closing the door. This is so the glass is secured up under the edge of the rubber seal, creating a wind-and-waterproof seal.
During cold, icy weather, what sometimes happens is that the glass gets frozen in the door, preventing the window from dropping down, making it difficult to impossible to get the door open. And, in the event that you DO manage to get the door open, it`s impossible to shut the door with the window all the way up, there`s a substantial danger of shattering the glass by slamming the door.
After putting up with this crap for a long time, I finally figured out a simple work-around to the problem....pool noodles....those long, polyurethane foam thingies that kids play with in the swimming pool. Using a sharp knife, slit one down the side. Put your window halfway down, install the slit noodle over the top of the glass, and trim to size, so it will cover the entire top of the glass. Using your key in the lock, use the "windows close" function to raise the glass until it just exerts a little pressure on the noodle.
This will give you the needed weatherproof seal, as well as leaving about a half-inch open gap at the top of the window, allowing the door to open and close freely, even if frozen.
Name:	Coupe Window #1 (2).jpg
ID:	579315   Click image for larger version
Name:	Coupe Window #2 (800x800).jpg
ID:	579316   Click image for larger version
Name:	Coupe Window #3 (800x800).jpg
ID:	579317   Click image for larger version
Name:	Coupe Window #4 (800x800).jpg
The road goes ever onward....
(R.I.P. Jever)
Old 10-16-2016, 02:31 PM
adwebinc adwebinc is offline
It's Bimmer, not BEEEEMER
Mein Auto: '01 750 | '91 850 | '00 5
You can also put some silicone grease in the window channels. Lubricates and makes it easier on the motor / regulators, but also prevents freezing.
'02 e46|M54 - Orient Blue|Beige|'Vert
'00 e39|M52 - Anthrazit Metallic|Grey
'01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line
'91 e31|M70 - Schwarz|Schwarz|M70
'13 328i Auto - Black Sapphire|Coral Red|Sport Line|Premium|CWP|GONE
'05 545i SMG - Jet Black|Black|Bamboo Anthracite|NAV|LOGIC7|Sport|Premium|Comfort Seats|CWP|GONE
'07 335i Auto - Montego Blue|Grey|Premium|CWP|GONE
'05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|NAV|Sport|CWP |GONE
'97 528i Auto - GONE
Old 10-16-2016, 02:33 PM
roverT's Avatar
roverT roverT is online now
Send a message via ICQ to roverT Send a message via AIM to roverT Send a message via MSN to roverT Send a message via Yahoo to roverT
Mein Auto: '04 ///M3 Individual
I just make sure I have greased the seals with rubber care and or olive oil or grape seed oil. Then buff it off after it soaks in. This repels water. Before I get out I make sure I hit the down button quickly. When I close the door the window should be sealed and doesn't go up that little bit. I've never had a problem with that.
There are many ways as Bob has mentioned. This is just my way.
--Trevor--
Vancouver, BC
Old 10-16-2016, 03:06 PM
saii1's Avatar
saii1 saii1 is offline
Mein Auto: 80 328xi 6m
Spray silicone on all the rubber seals will stop that too and it keeps the seals healthy over the years.. Only drawback it smells for a day or two but it's worth it
Sent from my LG-H901 using Tapatalk
Old 10-16-2016, 05:53 PM
Fast Bob's Avatar
Keeping it surreal
I normally treat all the rubber seals on the entire car with Armor-All 3 or 4 times a year. Keeps everything nice & pliable, but hasn`t proven to be terribly effective against freezing. Never tried the silicone grease....I have a tube of Dielectric silicone grease, but it seems a bit too sticky and messy for use on window seals though....
(R.I.P. Jever)
Old 10-16-2016, 06:28 PM
saii1's Avatar
Use the spray...it's a dry lube after it drys and ice can't stick to silicone
Old 10-22-2016, 01:45 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
My old E36 had the same issues. I would always get a hot glass of tap water to pour on the roof and cascade down the window. A bit more dangerous but it always worked for me.
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 11-03-2016, 12:11 PM
r20wla r20wla is offline
Mein Auto: bmw 330ci
ive always put a slight smear of light grease or vasaline
Old 02-22-2017, 09:57 AM
Trevon Trevon is offline
BMW Enthusiast
Mein Auto: 2012 M3
Greased seals have always done the trick for me, but I'm in Cali so it doesn't get that cold.
"Imagination is more important than knowledge." - Albert Einstein. Trevon AKA Mini
