E46 (1999 - 2006)
Old 04-13-2017, 11:06 AM
KrankE46 KrankE46 is offline
Mein Auto: E46 325XI
E46 intermittent starting issue
I have a 2004 325xi with 250,000 miles on it. 18 months ago it started to have an intermittent starting issue. typically it starts right up and runs as expected, once a day or sometimes more often it will turn over just as strong but won't fire up. If I turn the ignition off and pull the key out and wait 30 seconds to a min and try again it will usually start on the second or third attempt. I thought if I waited long enough the failing part would go out completely then I would know what to replace. Please let me know if anyone has had and resolved this issue. Thanks
Old 04-13-2017, 11:28 AM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Your fuel pump is quite likely failing at this point. Replacing it (and also the fuel filter) ASAP would be a good idea.
The road goes ever onward....
(R.I.P. Jever)
Old 04-13-2017, 11:40 AM
Thanks for your reply, I've look into replacing the fuel pump, cost at around $150.00. I would like to test the pressure at the fuel rail, do you know what that should be?
Old 04-13-2017, 12:00 PM
Fast Bob's Avatar
Keeping it surreal
~ 50 psi
It`s quite possible to have a "soft-fail" condition, where it doesn`t show up all the time.
(R.I.P. Jever)
Old 04-14-2017, 06:38 AM
DEADF15H DEADF15H is offline
Mein Auto: 2001 325i 4 door DD
~ 50 psi
^^^^^^This
Occasionally you can pull the seat up and tap on the top of the pump to get it going again. But that won't work for long.
Use a Siemens/VDO pump to replace. Easiest DIY ever, other than replacing a fuse.
Sent from my flame proof Samsung Note 4
Old 06-16-2017, 02:18 PM
I replaced the fuel pump and fuel filter. Still have the same issue, no change. Any other ideas on what could be causing the issue?
Old 06-18-2017, 01:09 PM
Beardog Beardog is offline
Mein Auto: 325xi
I have the same issue. Fuel pump, filter, and pressure regulator replaced a few months ago. Ignition switch may be next..
Sent from my QTAQZ3 using Bimmerfest mobile app
Old 06-18-2017, 01:11 PM
Mein Auto: 325xi
Mine starts like a champ, and then not at all! I left it overnight and it started up the next morning.
Old 06-20-2017, 01:39 PM
I have heard that starters have a sensor in them that tells the engine they are turning so the engine knows to fire. I've heard that bad spots can occur on the those sensors causing the engine to not fire during cranking. This causes what appears to be a completely random starting issue. Has anyone had this type of issue and resolved it by replacing the starter?
Any ideas would be helpful.
Old 06-20-2017, 02:55 PM
scottjoh scottjoh is online now
Mein Auto: 1999 323i
[QUOTE=KrankE46;10207427]I have heard that starters have a sensor in them that tells the engine they are turning so the engine knows to fire. /QUOTE]
I have never heard of such a thing. The engine uses the cam position sensors to determine engine RPM and current angle for when to fine. There is no sensor in the starter.
Old 06-21-2017, 08:26 AM
[QUOTE=scottjoh;10207562]
Could a failing cam sensor cause a starting issue. What other sensors could cause the engine to not fire?
