Old 05-10-2017, 03:42 PM
Baba3000 Baba3000 is offline
Mein Auto: Bmw 328xi
Bmw e92 coupe
Anybody know what would be the maximum size wheel and tires I can install on a 328xi coupe without spacers?
Old 05-11-2017, 08:42 AM
Viperbeemer's Avatar
Viperbeemer Viperbeemer is offline
Mein Auto: 2007 328 ix coupe
http://www.willtheyfit.com/
Art
2007 328XI sport package winter package
Old 05-11-2017, 11:48 AM
Cool site! Thanks bro!
Old 05-17-2017, 09:39 AM
JFudge335xi JFudge335xi is offline
Mein Auto: 2008 335xi
be careful with offset.
I bought my 335xi with staggered wheels and it is putting stress on my differential, which is an essential part of my drivetrain. DO NOT buy wheels or tires that are wider or have a different circumference between the front and rear.
Old 05-17-2017, 02:39 PM
Right but wider tires always hot on bimmers
Old 05-17-2017, 02:44 PM
Bought new OEM bmw oil filter from the deler parts store but noticed the filter says Mann filter. Is BMW get filters from Mann? The box was bmw original but the filter inside has Mann print. Just wondering
Old 05-17-2017, 04:58 PM
2NASpec's Avatar
2NASpec 2NASpec is online now
Mein Auto: 2012 328i Coupe N51
Mann makes BMW filters. Just go buy a Mann filter. Exact same part. Save your money.
2012 328i Coupe Alpine White
19" 403 M-Sport wheels on summer tires
Old 05-17-2017, 06:08 PM
F10-N52 F10-N52 is offline
Mein Auto: F10 N52 RWD
why not? is it because of mismatched sidewall size?
EG. if the front tires are 225/35/r19, and the rear is staggered, then the rear must be 255/30/r19. the smaller sidewall in the rear matches sidewall size and fixes any issue you may have with xdrive.
are you saying to avoid a staggered setup in general, or only if you have xDrive?
Old 05-17-2017, 08:13 PM
Do I need to do wheel alignment each time I swap between 17" stock wheels to 19" summer wheels?
Old 05-17-2017, 09:02 PM
2NASpec's Avatar
Nope. That does not affect the alignment in any way.
Old 05-17-2017, 09:32 PM
+1.
I've been noticing some tranlining over grooved roads and the wheel sometimes pulls to the right particularly when braking. Wanted to make sure this is normal.
Otherwise, switching to a lightweight set of 19 inch tires with performance tires can go a long way for overall performance of your vehicle.
Old 05-17-2017, 10:02 PM
2NASpec's Avatar
Originally Posted by F10-N52 View Post
+1.
Lol my 18's handled much better and was much more comfortable on the bad roads here than my 19's. Which is a given. But I love the way the 19's look so I keep em on.
Old 05-18-2017, 07:51 AM
Which tire sizes did you have?
My 19's are a little heavy, but barely any heavier then the 17's they replaced. Went from 55/r17 to 35/r19. Massive difference in handling.
Old 05-19-2017, 06:04 AM
I feel like the steering is harder to maneuver. This especially when I do parking and take it out from driveway. Certainly would be very difficult for a lady to steer without strength. Is this normal in bmws or a powersteering issue?
Old 05-19-2017, 06:48 AM
Uh check your power steering levels. You must want to do a full fluid flush as well.
If your power steering fluid is full, then that is how heavy the steering is supposed to be.
Old 05-19-2017, 07:31 AM
Im just saying for xdrive. Bmw said the setup i have now is damaging the transfer case's wet clutch and it could be a 4,000 dollar repair if it isnt corrected
Old 05-19-2017, 07:37 AM
That's a load of **** they are trying to rob you of your money as usual.
If you have a staggered setup eg 225/35/r19 front and 255/35/r19 rear yes, that's not good for your transfer case.
BUT, if the rear sidewall size is one smaller then the front (225/35/r19 front 255/30/r19 rear) sidewall thickness is matched front to rear and there will be absolutely no damage done whatsoever to your drivetrain.
Old 05-19-2017, 07:38 AM
+1. Can't go wrong with OEM.
Old 05-19-2017, 07:44 AM
Thanks for comments! Btw does e92 have PS drain plugs to flush ? I saw in youtube they pump out oil and refill reservoir. They don't drain or remove plug in the process
Old 05-19-2017, 07:47 AM
veery veery is offline
Mein Auto: 2011 328i X; 2005 X3
Likely you are experiencing the normal response of hydraulic assist power steering. It is hard to turn at slow speeds - like when parking - because of the mechanical feedback felt through the system. It is what makes your car handle like a BMW when doing the twisties.
Old 05-19-2017, 08:17 AM
If you have a staggered setup eg 225/35/r19 front and 255/35/r19 rear yes, that's not good for your drivetrain
I have 275/30/R20 rear
245/35/R20 front
Ive heard a lot of possible problems with my setup so im buying a square set of wheels just in case
Old 05-20-2017, 10:34 AM
Trust me, you're not going to have any issues. You don't need a square setup man.
What you have is perfectly fine to use with xdrive.
Old 05-21-2017, 03:16 PM
Anybody got suggestions for backup reverse camera installation for a E92 coupe? Also thinking about upgrading my factory radio to the chinese 7" android6.0 Deck. They say those are plug and play type. Any issues ?
Old 05-25-2017, 01:28 PM
Is it ok to use 5W30 castrol full sythetic extended ? Bmw does recommend Castrol but not sure if there is a particular European formula?
Sent from my LG-H831 using Bimmerfest mobile app
Old 05-25-2017, 01:40 PM
I would use liqui moly 5w40.
BMW's new shell oil is also good. But use 5w30 or 40
