Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 05-25-2017, 12:36 PM
timekpr1 timekpr1 is offline
Mein Auto: 2017 i3REX
Need Coding HELP SCREWED UP
I had everything done and decided to make one last change. I wanted to change the close delay between the windows up and sunroof when using the fob. Somewhere along the line I did something wrong. When I hit the lock button the windows start to go up but the alarm goes off. Anybody have any ideas? I can drive it. I just cannot lock my doors.
2017 i3REX Deka World
Old 05-25-2017, 12:41 PM
or - How do I reset the codes from a previous backup. I did a backup before the start of each new coding session. They are .xml files.
Old 05-25-2017, 12:45 PM
God-Follower God-Follower is offline
Moderator
Mein Auto: 2015\2016 i3s, F10 535d
Before you go changing any coding around, plug your PC back into it and re-establish the connection. Then make sure you hit the disconnect button in E-Sys before you unplug the cable.
Usually this is caused by the Ethernet still seeing activity/open comm port caused by the computer being still plugged in or the connection not being properly terminated.
Old 05-25-2017, 01:04 PM
Sir, if you are ever in Eloy, AZ I will buy you dinner. You can see the current temp in my garage. Add 30 degrees for nerves and that would cover it. Your suggestion worked. Thank you.
Old 05-25-2017, 01:06 PM
E66 Guy E66 Guy is offline
Mein Auto: I rebuild BMW's and Tune
Which program did you use?
-Mechanical Engineer, BMW Technician, Diagnostic Specialist, BMW ECU Tuning Technician , over 20 years in business, Shop Owner
Old 05-25-2017, 01:12 PM
Moderator
No problems man, glad it was an easy fix. And I know the feeling, after I coded my car successfully I began coding my wife's car. When I was done I brought her out to show off her new features, and couldn't make the alarm stop going off...the things we learn!
E-Sys is to my knowledge the only program capable of changing coding flags in the i3 models(or any F/I/G chassis) currently.
Old 05-25-2017, 01:17 PM
OK...I came too late glad everyone got it done great job gentleman!
Old 05-25-2017, 01:22 PM
E-Sys.
