Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 05-28-2017, 07:01 AM
jiangleo jiangleo is offline
Mein Auto:
Increase DRL brightness level via E-sys issue
Hi, guys!
I tried to increase the DRL's brightness for my 2015 i3 via E-sys. I used the Coding Parameters (cheat sheet) I found from this forum. But I am not able to locate the code line in the e-sys. Under 3062, there are no such things as MAPPING_STANDL_V_L_PWM_LEVEL_1 or MAPPING_STANDL_V_R_PWM_LEVEL_1.
Any of you successfully had this done? Thank you!
Here are the codes from the sheet:
BDC Body Module:
Increase DRL Brightness to be brighter (increases voltage to the LED Bulbs)
3062 ***61664; MAPPING_STANDL_V_L_PWM_LEVEL_1 set to: 13.7v
3062 ***61664; MAPPING_STANDL_V_R_PWM_LEVEL_1 set to: 13.7v
3062 ***61664; MAPPING_PARKL_1_V_L_PWM_1_LEFT set to: 13.7v
3062 ***61664; MAPPING_PARKL_1_V_L_PWM_2_RIGHT set to: 13.7v
